Getting rid of the rattle on a Vox VT40+
VinylfanVinylfan Frets: 33
Hi
I have a Vox VT40+ that I bought a while back and don't use that often.  When I do use it, I notice what can only be described as a 'rattle' or some kind of hiss.  Seems to go down/lessen if I turn the treble down but then I don't have any treble control.
Any ideas as to whether it can be solved or reduced in some way?
The amp itself is great - plenty of options for me, plenty powerful enough for home etc. - just wish I could get rid of this annoying rattle.
Cheers
  • ICBMICBM Frets: 71950
    Is it reduced if you turn down the power level control as far as possible and turn up the volume to give the same overall volume?
    It could be a microphonic or faulty preamp valve. My AD15VT is quite hissy on a couple of the settings, and it's related to using the valve in a particular mode. (Boutique Clean, AC15, AC30 and Boutique OD - I know the VT40 doesn't have quite the same settings.)
    I can't remember having opened up a VT40, but if it's anything like the AD15 it will quite a pain to get into and change the valve...
  • VinylfanVinylfan Frets: 33
    edited May 2018
    Hi
    Yes, I just played around with it a bit more.  By turning down the power value and turning up the volume the hiss reduces quite a lot (to nothing in some cases).  Turning the treble down reduces it even further.
    The amp settings where the hiss was really noticeable were - US Blues; AC£); UK Metal; US Highgain; BTQ Metal - this was before turning down the power and upping the volume.  This was with all other effects, reverb, delay etc off.  Gain was set to around 10 o'clock for all of them so it was only the power level and volume that I was changing.
    So is this normal or is the valve faulty in some way?  Any other tests I should do? Should it make a difference if I leave it for the valve to get warmer or doesn't it work like that?
    Cheers
    I think it might be normal. I tried two different valves in mine - other than the stock one - and they all did it to more or less the same amount. After that I got fed up of fiddling with it - it's quite a nuisance to change the valve :).
    The modelling circuit does actually change the valve bias and whether one or both halves of the valve are used, it's not just a token 'valve in the circuit'. It's slightly annoying because the noisiest setting on mine is the AC30, which is - possibly not by coincidence - the best sound in the amp. (And worse, the AD15 does not have a power control, being one of the smaller amps in the range - so I can't fix it like that.)
    The valve will be fully warmed up after only about thirty seconds to a minute, after that it won't make any difference.
    @ICBM thanks.  I'll leave it as it is then.
  • FunkfingersFunkfingers Frets: 14320
    It is.
    A friend of mine simultaneously owned two ToneLab type amplifiers. Peering through their rear ventilation grilles, it was obvious that the valve in one of them lacked a healthy glow. Almost every screw on the outside of the amplifier needed undoing to access the valve. It was also necessary/advisable to disengage the block connector on a flying lead to avoid the possibility of damaging it.
    Fortunately, my friend has since sold both VOX amplifiers. If he had ever asked for my assistance a second time, I think that I would have resorted to something like this.
    Be seeing you.
  • VoxmanVoxman Frets: 4718
    I assume you mean Valvetronix amps and as you could see the tubes through the rear grill these would be the later chrome amps.  The valves don't glow because unlike the original blue series valvetronix amps there's only low voltage going through them. Any glow you saw was from an led used for marketing effect only. The led had likely packed up in the one with no healthy glow.
    Changing the valves in these amps is actually relatively easy although it's rarely needed because they should last the life of the amp particularly as they only have low voltages going through them as I said. It's the blue series that are awkward because you can only see the valve tips sticking through the chassis and in the blues they do have much higher voltages going through the tubes. But duct tape wrapped around the tube end and gently wiggling it lets you get to these without having to undo the chassis.
    edited May 2018
    That’s not exactly true.
    The valves do glow in the VT series, and there is no LED. Although there is no high voltage applied to the *plates*, the filaments are operated normally.
    Getting to the valve requires taking the chassis out completely, and getting it out of its holder without taking the PCB out is possible but tricky - there isn’t enough room to reach it easily by hand, you need to use something like a flat screwdriver to lever it out, and a couple of bits of wood to grab it. Guiding the new one in and pressing it into the socket is a similar faff...
    This should show why!
    http://www.voxshowroom.com/ct/amp/uk/AD_series/ad15vt_tube.jpg
    http://www.voxshowroom.com/uk/amp/ad15_hood.html
    (The description at the bottom of how to change the valve is wrong, by the way - you need to remove, not loosen, the eight chassis mounting screws, and also disconnect the speaker to get the chassis out.)
    Seems like a lot of hassle!  If it was a simple open, remove, refit job then I'd have considered it but I think I'll only end up causing more damage!
    Trust me, I'm a professional amp repairer and it's enough of a hassle for me that I've left mine with the slightly noisier valve I put in to see if it cured the noise with the first replacement one but didn't :).
    I'm not 100% sure if the layout of the VT40+ is the same inside, but I think it's likely to be at least similar.
    @ICBM - thanks, that has reinforced my decision to leave well alone!  If you're a pro and find it a hassle then I'll undoubtedly just break it!  I'll put up with the noise and at least have learnt a few ways to lessen it via this thread.
    On a separate note, I've been thinking about a valve lunchbox head as I have a spare speaker.  Will start a new thread for that.
  • BridgehouseBridgehouse Frets: 24578
    Pah -- that's like a professional car mechanic running a crap old escort with noisy tappets cos they can't be arsed to replace them ;)
    i'm not getting involved in this - you girls fight it out between yourselves!
    It's a play fight - don't worry.
    It's all part of the "try to prove @ICBM wrong on something for a change" challenge.
    It's a glorious feeling when you do. Apparently..
    Its ok, I figured that.  Still better to step aside when the grown-ups/big boys are fighting.
    Er, am I grown up or a big boy? Cos I can assure you....
    Well, I haven't been around here that long but I have heard tell of the legend of Bridgehouse and his bigness (sure I just made that up). So on that basis, I would go with big boy.  That suit you Sir?
    @Vinylfan - any pictures that may have been PM’d to you are fakes.
    @ICBM - too late for that kind of backtracking now.
    edited May 2018
    @ICBM ; it depends on which generation of Valvetronix. There is no led on the first generation ie AD15/30VT but the VT15/30 etc and the VT+ range do have led's, and the OP's amp is a VT40+ which has an led behind the tube. The valve glow in the VT and VT+ is very faint and you won't normally see it in daylight...hence the led. The valve change on the VT and VT+ is also easier I believe than the AD15/30VT models.
    Voxman said:
    @ICBM ;
    it d
    Ah, that would explain it. I thought the + range would be just 'tweaked' versions of the VTs with a different preamp. I know we've said this before, but why do they have to keep changing *everything* the whole time?! Surely it must cost them a fortune in R&D, and each time it seems like they make them worse...
