i also love that the neck pickup gives a proper normal deep bass sound you'd expect from an electric bass bit the neck gives a more delicate (not bright but lacking the deepness of lowest freqs with some higher components added) which can work really well with an acoustic mix. Add the bridge damper and its very flexible for what your after
Bona.
I am yet to see a guitar/bass bridge string damper system that does not interfere with the intonation. Before ICBM mentions Rickenbacker, even thumbwheel adjusted individual string mutes are problematic when more than lightly engaged.
Would even work well with an archtop floating bridge style piezo or piezo and mic mixing system to get a good acoustic and woody tone. Something from K&K would sound immense i reckon.
Apparently you can fit a Jazz bass pickup in the space for it, although quite why you'd want to I'm not sure - there can't be enough string movement there to produce a useful output, I wouldn't have thought.
