Hi,
I'm mainly a singer and strummer and I've got a minor issue with a 2002 Gibson J45 that, otherwise, I really like. I seem to be getting an annoying pinging sound as I'm playing. I thought it was something with the nut or bridge but I've had them checked and they seem fine. So I've now come to the conclusion that I'm the problem.
Specifically, I think I might be catching the base of my chubby first/pointing finger on the open E string.
Now this is probably down to a terrible technique on my part that I should get some advice on but my first call is to make the guitar take the blame instead.
To be fair, I've never had this issue playing other guitars and looking at the nut, the slot seems quite close to the edge of the fingerboard. Is it worth thinking about having a new nut cut that could bring the strings a little closer together and shift the strings away from the edge a little? Is this workable? Any thoughts or advice? (Other than get some lessons, get new hands or get your fingers to the gym to lose a few pounds? etc.)
I should say that other people playing it don't seem to have this issue - they love it!
Thanks for any feedback.
Best,
cam f
I have the opposite problem on bass - I play with finger on the back of the neck, and with my bass playing I like to mute every string that isn't being played so I'm fingers everywhere!
https://www.dropbox.com/s/mwcalyblochnsox/IMG_3632.JPG?raw=1 ;
The J-45
Thansk for taking the time to respond, guys. Much appreciated.
I think with a new nut you need to be careful you aren't fixing a symptom rather than the problem - otherwise you could be severely restricted in guitars you can play in the future...
The ES-125
Worst case scenario is you have a new nut fitted with the 125 spacing and it doesn't fix it - you can always put the old nut back.
Who put the low E string on the J-45?
I wonder if the 125 has pushed you to hold your hand in a certain way @camf ?
I'm only pushing down this line as I had a similar issue 20 years ago which I had to teach myself to correct.. and I've spent a lot of time on hand position and muting with bass.
Sadly, I think I might have been guilty of the low E offence too.
My concern was I didn't want you to mask a potential issue that might rear it's head in a few years when you come to try another new (to you) guitar and it manifests itself again..
It's probably a combination of both. Worth looking at the hand position as well just in case.
