You often hear people say that they tried a guitar in a shop and had to buy it because it sounded perfect, and out of the 5 they tried, it was "the one".
So much can affect tone, that it makes me wonder if this is just an illusion. Production methods now are so consistent, that isn't it fair to say that the age of the strings, the setup and the height of the pups ect, have more to do with it? An example is a guitar I bought. It arrived and sounded very base heavy to me, not the tone I liked. So i changed the strings, did a setup and adjusted the pups until I found the tone I wanted.
I'm surprised by the number of guitarist that can't do basic setups on their guitars, and I'm wondering if it's this lack of knowledge/ability to alter the tone of their guitars, that is creating this belief about perfect guitars.
If I summarize what I'm trying to get at, it's that there are so many adjustments you can make to a guitar that will alter the tone. Just because a guitar doesn't sound spot on when to pick it off the shelf, doesn't mean it can't sound perfect with some tinkering.
Am I right, or am I completely missing something?
Tone chasing is in your head.
or the strings
or theplektrum/pick
or the amp
of the cab
or the cables
or the humidity
or whether the serial number has been scratched out
No I think you are right.. Good tone can depend on ones mood for instance.. Ive had times when I am playing and dial in a great sound I am happy with.. A couple of days later I can come back to the same guitar using the same settings and not be so happy with it?
Its also something that evolves over time.. So what you like now you may not like in a year because you have gotten in to some new music which has changed what you think..
Theres very little right or wrong about it all.. I say just play and enjoy.
Like when a lot of players start young and want a distorted sound and in the beginning most of us go as heavy as possible. Its only later down the line you realise that it sounds much better with a more subtle just breaking up type of distortion.
I still have to believe that a lot of it comes down to technique and practice more than anything. A good player can make any guitar sound good..
http://www.rabswoodguitars.co.uk/
https://www.facebook.com/RabsWoodGuitars/
My Youtube page
The problem is it is fleeting.
The way to deal with it is simply to stop trying to fill a hole in yourself with 'a thing'.
Throw yourself into your playing and then it doesn't matter about the gear- you can still buy instruments as you can afford to but it isn't necessary.
I didn't buy a guitar for about 2 years- I've bought 3 this year- because I had the cash and wanted them, not based on the illusion they would make me a better player.
I've said (more than once) that if people spent 1/10th the time working on transcription that they spent obsessing over minute differences in tone then they'd be much better musicians.
If 10 players played 10 nice Strats, LP's or 335's I guarantee there will not be one clear winner - Each can be similar but the finer nuances are different and as such we all gravitate towards something that possesses something we like - call it mojo or whatever you want to - I'm not sure a perfect guitar exists - The best guitar certainly doesn't as a Tele, a 335 or a LP have their own character and no one guitar does it all
However, in a store, or indeed any guitar that is offered for sale, I do believe that it should be set-up to try and entice you into buying it - as such a good set-up, in tune and clean strings should be on all guitars, allowing you to evaluate it/them - Fully appreciate the fine tuning of the set-up is a matter of taste, but the principle presentation should be good - So yes a good set-up is paramount - But equally it is good if you can fine tune the basic set-up to suit your own taste, as required as only you know what suits you and your technique
I recall years ago when I worked for a larger company, staff would say they can't sell such n such a guitar - So I look at it, find it covered in finger marks, dirty strings badly set-up etc etc and sitting in the part of the showroom I call the sad corner - I suggest they clean it up, set it up re-string it, re-display it and even re-price it - Low and behold a few days later it is sold - So yes presentation is key
I need perfect string separation in chords to allow me to play any combination I like without mushing out, and I need the low strings to be clearly defined with a bit of a twang, even with everything flat out.
That all has to happen at one amp setting and be totally controllable from the guitar, so yes, it takes an immense amount of fine tuning which can become an obsession.
One thing my obsession does though, is to remove the magic, mythical element a lot of people are chasing. I'm too bogged down in cap values, pot tapers and magnet swapping to be interested in any of that cosmic muso stuff.
That anyone believes that on a given day 35 semi skilled workers on a factory line in Korea breathed a bit of special magic into guitar number 384 that morning always makes me smile.
I like a bit of tone chasing but I've never understood the "that guitar was the one" thing - especially trying out in a guitar shop which I think is a terrible place to try out a guitar, you're not trying it with your amp/pedals in a comfortable environment. I'd much prefer to take a risk on-line and then return if I don't like. I always think those who try a guitar for 5 minutes and think it's "the one" are the same that probably fall in love after a first date.
I chased, caught, released, chased, caught, released (continuously for 20 years), finally happy...won’t change!
though...my friends amp sounds incredible.....hmmm....
So is "well, it seemed like a good idea at the time."
Most of the time, the band member fussing over achieving some hypothetically "perfect" tone is the guitarist. Bassists tend to already understand about fitting in with the overall sound of a composition. (Perhaps, this is what @Bridgehouse was attempting to post earlier?)
tbh your more likely to get it by practising and when ready to choose equipment going out and playing and auditioning a pile of kit then you ever would be buying something that sounded good with xyz artist or in a demo video.
Actually ive been keeping this quite..
This is the REAL secret behind more tone
https://i.imgur.com/ENxuxAC.jpg
My Youtube page
That being said, it is often surprising how particular these guys can be when it comes to the tiniest perceived differences in tone to their own ear... I cannot hear that much difference when I am listening, which I guess does indicate this tone is largely in the ear of the beholder.
I think there is a lot more variance in the tone of vintage instruments compared to todays CNC machined, modern guitars. I also think Fenders have more diversity of 'tone' than Gibsons do. Maybe it is the combination of body mass and/or the way the ash or alder ages compared to Gibson's mahogany but I guarantee you two 60's Teles or Strats with identical set ups, strings amps etc will sound subtly, but noticeably different in tone. But hey, this is all part of the fun of vintage which for many is a big part of the appeal...
For instance if I play a large open G chord on my SG with a crunch sound and then the same on my DGT. I'll hear more top and bottom on the DGT and a more pronounced mid range honk on the SG. If I played that to a non guitarist they might say one is brighter etc but they won't agree that the price difference between the two guitars is justified.
I believe a more expensive amp and guitar will generally sound better. But the price difference is something guitarists justify to themselves (I'm as guilty as anyone else)
I agree 110% with bucket about it being a mental state of mind thing. If I don't play for a few weeks, I'm far more at ease when I pick a guitar up. And sometimes you just have off days.
