12 fret guitars
DavidReesDavidRees Frets: 335
I have noticed over the years that a number of acoustic players automatically capo at the second fret - now this may be to accommodate the range of their voice for the song in question, it may be about tuning down with thicker string to get a more 'relaxed' feel in standard tuning but is it also possibly about getting something of the feel of a guitar where the neck joins the body at the 12th fret, particularly when sitting down to play - just thinking out loud really ...
  • GagarynGagaryn Frets: 1553
    People do this for either of the first two reasons you mention. Not sure it achieves your third proposition, a big part of the feel of a 12 fret is due to the corresponding bridge position.
  • AliGorieAliGorie Frets: 308
    Dave, theres a whole lotta confusion re 12 fretters - from how I read u'r suggestion u'r suggesting that the neck shaft / fingerboard being 1 to 1 1/2 inches  - hmm, what 'bout players like me who regularly play 'up the neck' or even pick up a banjo or mandolin or cittern etc. with different neck / fretting proportions.
    But then I play Low whistle and Uilleann pipes which would be impossible for 12 fret capo's - capos are out.
    just some balance.
  • crunchmancrunchman Frets: 11446
    The main benefit of a 12 fret is the bridge positioning.  It's closer to the middle of the soundboard, and that really seems to help the tone.  The best sounding acoustic I ever played was a 12 fret Santa Cruz.  Thankfully, the neck dimensions on it don't give me massive pangs of regret that it was outside my budget.
    ha ha, it's like QI - unmentionable word - phrase.
    'Lower bout'.
    This was the most (externally) obvious - bridge is further down the s/b.
    When you look into it from a structural / design point of view u'll find that the bridge to X brace (system) and dimensions on 'older' guitars - 30's to '60's is actually the cause of the 'better tone.
    look here -
    Many people prefer the slightly 'deader' and more even sound of a capoed guitar, especially for recording. It means there is less of a contrast sonically between the open strings and fretted strings.
  • DavidReesDavidRees Frets: 335
    thanks for the comments people - I've never actually played a 12 fretter so I suppose I should to see what it's like. I posted my question because I've noticed a different kind of playing position/comfort thing going on whilst cradling my small bodied acoustic with the capo on the second fret ...
    'Lower bout'.
    look here -
    Haven't looked into the acoustics section for a while, so resurrecting a slightly older discussion, but it's not purely the bracing.
    I don't know if it's in the current line up, but when I was looking at good acoustics several years ago, I played the slot headstock 12 fret Martin HD28VS, and also the 14 fret HD28V.  They both have the vintage style bracing, but they do sound different.  I had a 12 fret Furch Dreadnought for a while as well.  That had a different tone to the 14 fret version.  To me, if you are looking at dreadnoughts, the 12 fret sounds a bit more open, and doesn't have the big (overwhelming??) bottom end that a 14 fret guitar has.
    The latest Martin D18s and D28s have gone back to what they call "forward-shifted" bracing - basically pre-war spec.  As far as I know, they changed the bracing (on dreadnoughts at least) in the mid 1940s.  I'd agree that the tone is better with the "forward-shifted" bracing.  To me that makes a bigger difference than scalloping it.  An HD28V (forward-shifted and scalloped) sounds a lot better than the older HD28 which was scalloped but post war positioning.  I'm not sure what the spec is on the latest HD28.
    thanks @crunchman ...
  • LewyLewy Frets: 4182
    Forward shifted, scalloped for 2018 "Reimagined" HD 28.
    They changed the D18 a few years ago (2012?).  Not sure if it was scalloped, but forward shifted at least.
  • JayGeeJayGee Frets: 1257
    I’ve occasionally used capos to move a stretchy bout of fingering from “I physically can’t do this” domain to the realm of “I can just barely manage it”...
  • LegionreturnsLegionreturns Frets: 7965
    I have a Takemine CP3 New Yorker which is 12th fret joined. I use a capo because I'm shit.
    Hope that helps
    yeah, being a novice builder I simply refer to the 'original' models bracing - the source.
    Including bracing profile + positioning + materials used, timber / glue etc.
    Thats what created the desirable sound.
    Martins (deliberate) marketing shenanigans are designed to move units - cause they've run outa product ideas decades ago.
