If someone is singing backing vocals too loudly then I need them to HEAR that they're too loud, I'm too busy to pull back faders on errant vocalists. A hostile glare from the lead singer is enough.
If they both had their own separate "more me" mixes neither of them would know when to pull back.
Supplying singers with a full band mix is an entirely different ball game.
In the absence of a sound man, all we can do is rely on a trusted audience member to give hand signals if anything is wildly out. I’ve been at the mercy of ‘sound men’ before - the real problem is trying to find one that has the faintest idea of what they’re doing. I’ve seen so many blokes in various pubs twiddling away but achieving sod all apart from making the sound even worse. Only once did we get a good chap. I don’t have much trust in people proclaiming to know how to operate a mixer.
I suppose in an ideal world, I could stick a couple of mics at the back of the pub and have the ability to switch my in ears to those every now and then to check on the mix !
Also chips are "Plant-based" no matter how you cook them.
Using a couple of JBL Eon Ones as FOH also means that we can all hear vocals everywhere in the room anyway, even the singers could if their IEMs should die.
Personally, there aren't many audience members I would trust to give me solid, impartial advice on my FOH sound.
We get around not having a soundman by soundchecking a little longer.
We play one song without keyboards but with full backing vox - the keys player goes out front to check levels to ensure everything is balanced
We then play one song with keys - I go out front and check levels to make sure the keys are balanced with everything else.
Finally I also record the soundcheck for each gig from out in front of the stage, and review it quickly to ensure that everything things are definitely sounding balanced.
Once it's set, none one touches so much as an EQ knob under penalty of death!
In our case, it helps that we use a digital mixer which recalls our most commonly used settings and all the monitor mixes - this way half the work is already done and we only have to make minor tweaks (usually) to account for for the room.
