This weeks update. My Ernie Ball VPJR started to go a bit mental so I got the Boss one as it's nearly half the size I had room to put a 3 way switch to control the superego. I also mounted a bright onion patchbay underneath to help tidy it up.
You should be able to click on the pictures to see underneath.
https://i.imgur.com/QwxsM2t.jpg
https://i.imgur.com/KrePP4x.jpg
Here's mine - low cost, compact and bijou. I've done a couple of gigs with it and I'm pretty much there. Gold one is a @handsomerik Fatpants, purple is a Thorpy SHO and the black is a Thorpy OCD.
Long time lurker!
Here's the board I put together this week.
It's been sketched out in my brain for a while now. I downsized from a PT Pro to a Mini a number of years ago to keep things simple but –– whilst I think discipline is good –– I really needed some breathing space for a tap delay and (eventually) a reverb pedal. So here's my Metro 24. It's the first board I've owned for new, actually. And it covers my entire sonic turf which is really satisfying. Trying to keep things clean... for now...
It’s not exactly neat like some of the beautiful ones above and the sounds are limited to just a few tonal enhancements and one or two special effects, but it’s got everything I need and everything’s easy to get to.
Thanks @ICBM!
https://youtu.be/W-kjhEB0VqI
From memory the Whammy is harder to true-bypass, unfortunately - and the stock bypass is notoriously poor.
Yes the whammy mod involves cutting tracks and some jumper wires and the switch. I did it on my IV but then stupidly sold it.
