Why do people use big amps?
  • mr-macmr-mac Frets: 200
    lukedlb said:
    I’ve never tried this: turning the cab to face the stage wall, turning up the amp and gigging on the reflected sound, which should be a little more dispersed and the highs cut.
    Anyone ever tried such foolishness?
    I’ve seen several people gig with their amps at the side of the stage facing across it. Presumably so they can hear themselves without blasting the front of the audience. There’s also the Springsteen method of having your Marshall cabs lying almost flat on the floor ( Bruce must play larger pubs than I do).
    Some sound men will request this as the player gets their volume with much less sound projecting forward and contaminating the mic'd sound from PA.  Also can create all sorts of phase and cancelling issues if sound from cab is too loud as wave isn't aligned with pa one.
  • p90foolp90fool Frets: 31580
    slacker said:
    Oh I forgot every situation that sounded great had one common theme, there were no knobhead in the band.
    This is the crux of the matter.
  • robgilmorobgilmo Frets: 3448
    So guys, what if the type of music you play requires a perticular amp which just happens to be loud as hell, if its played quietly it wont sound right at all, what do you do then?
  • shaunmshaunm Frets: 1598
    This weekend I’m gigging my JTM45 with a 2x12 cab for the first time. I don’t know if it’s going to be too loud or it’s going to be a good fit.
    The last time I played this venue I used a Fender Supersonic 60 and it was way way too loud.
    The time before I used an 18 watt amps and I didn’t cut through the band at all.
    On paper it looks like a good fit.
  • ICBMICBM Frets: 72308
    Get an attenuator.
    ICBM said:
    Get an attenuator.
    Yep or sound crap to the audience :)
    Take up the accordion?
    This is why people have Kempers,et al.
    Attenuator? Something I know very little about, can you guys recommend one?
  • vizviz Frets: 10691
    edited May 2018
    Yes I do, with 100W through a 4x12 for the deep roar, but I don’t have it that loud and I mic it through the PA so it’s not directional. And I have a wedge monitor 1x12 at the same ohm rating so I can hear myself really clearly.
    For the Peavey?
    THD Hotplate, 4 ohm model.
    ICBM said:
    For the Peavey?
    Wow, that's not cheap is it? Will that sound exactly like the amp at full tilt but at a decent, usable volume?
    No, not exactly. There’s no way of doing that since some of it is from the speaker compression - but it will be closer than any other method.
    No attenuator capable of handling a 100W+ amp is going to be cheap, unfortunately...
    Cool , Ill still get that gritty , barking distortion? They seem to go for around 150 second hand so its not a massive spend if it gets me close to where I want to be.
    I like big amps coz it gives me the horn and a load of groupies
    edited May 2018
    You get an erection and it attracts women? Do you wear Sex Panther?
    https://i.pinimg.com/736x/8b/21/e9/8b21e9af45297a54818f8a687ba26e2d--little-kitty-the-panthers.jpg
  • sweepysweepy Frets: 4183
    Big Amps = Big Transformers = decent bottom end and dynamics, that’s all there is to it imho
  • ToneControlToneControl Frets: 11891
    if you're not using a PA for the guitar, then a 100W clean amp is perfectly sensible
    But for heavy power-stage distortion, 20W or 30W tops I think.
  • zepp76zepp76 Frets: 2534
    @shaunm ;I look forward to hearing how you get on. Have you considered having a PPIMV fitted? I have one on mine and it helps keep things sane without losing tonal quality.
    Tomorrow will be a good day.
    Yes - although it still won’t give you the sound and feeling of the speakers working hard, you’ll still get the power amp distortion which you otherwise can’t get with the amp’s controls alone.
    There are other attenuators, some of them cheaper, but I know the Hotplate works well with high-powered 6L6-based amps like this. (Attenuators can be a bit amp-specific.)
    Be aware that it does put a fair amount of strain on the valves and other power amp components, no matter what the makers say...
    I watched Dan Patlansky a few weeks back at a club venue. He had his 50w Dr Z head going into a 4x12 cab turned backwards. No idea how much was then going through the PA, but he sounded great.
    Talks about it at about 2:15 in this vid...
