The last time I played this venue I used a Fender Supersonic 60 and it was way way too loud.
The time before I used an 18 watt amps and I didn’t cut through the band at all.
On paper it looks like a good fit.
This is why people have Kempers,et al.
THD Hotplate, 4 ohm model.
Wow, that's not cheap is it? Will that sound exactly like the amp at full tilt but at a decent, usable volume?
No attenuator capable of handling a 100W+ amp is going to be cheap, unfortunately...
https://i.pinimg.com/736x/8b/21/e9/8b21e9af45297a54818f8a687ba26e2d--little-kitty-the-panthers.jpg
But for heavy power-stage distortion, 20W or 30W tops I think.
There are other attenuators, some of them cheaper, but I know the Hotplate works well with high-powered 6L6-based amps like this. (Attenuators can be a bit amp-specific.)
Be aware that it does put a fair amount of strain on the valves and other power amp components, no matter what the makers say...
Talks about it at about 2:15 in this vid...
