How to tell if body is made of laminate or solid wood
Just curious, is there an easy way to tell if the back and sides of an acoustic are made from laminate or aolso wood?
  • FuengiFuengi Frets: 2849
    Check the grain inside and out to see if it matches. If it doesn't it's laminate for sure.
  • thermionicthermionic Frets: 9499
    Many of them take care to match the grain between inner and outer plies, or at least have similar grain. I have a laminate back and sides guitar and the back is two bookmatched pieces.
  • ICBMICBM Frets: 71960
    Take the endpin out and have a look at the edges of the hole - that will usually tell you what the sides are. It's rare for the back to be different, although not totally unknown.
  • ClashmanClashman Frets: 175
    Just google the model  number and make =)
