Mesa Boogie Lonestar Special/Classic - opinions?
13»
  • imalrightjackimalrightjack Frets: 3741
    @RiftAmps ;
    Do you know the easiest way to access the innards?
    Trading feedback info here
    My band, Red For Dissent
    I’ve just gone to set up in 4-cable method with my Fractal FX8 and get no sound unless I bypass the loop. In which case I get no wet sounds. Anybody any ideas?
    I swear it did work...
  • arayadisarayadis Frets: 47
    Versatile, rock solid, good for your taste I think.
    Are you sure the wiring is correct, the connections should be
    Guitar > Fractal Guitar In
    Fractal Loop Send > Amp In
    Amp Loop Send > Fractal Loop Return
    Fractal Output > Amp Loop Return
    Then make sure both the Fractal has the correct loop settings and the amp doesn't have a loop volume control that is turned down.
    @imalrightjack ; - check out Andy Timmons use of Lonestar and his tryout of the MKv25 - he gets some very tasteful tones out of both - I own a MKV 25 head - stunning bit of kit in a 8Kg box !
