Spotting a fake SM58 ?
Emp_FabEmp_Fab Frets: 24263
I’ve been asked to repair a knackered SM58 although it’s heritage would suggest it’s very likely genuine (having once belonged to a band that got to #4 in the UK singles chart), I have my doubts as it fails a few of the checks listed here: https://fakesm58.wordpress.com/
Namely, the threads on the body are black, the weight is wrong and the foam inside the grille is black not grey.  However, everything else is right; the green and yellow wires and the red quality control printing on the circuit board.  The sticker has long vanished from the capsule though.
Now... I’m wondering if this mic has had a third-party grille fitted at some point, as although the width of the central band is correct at 4mm, the shoulder around the thread is sort of halfway between the two examples on that site.  Neither one or the other.
So, in order to confirm my suspicion, would some kind soul with a known genuine SM58 and a set of digital scales be kind enough to unscrew the grille and weigh the mic, then the grille for me please ?
The one I have here weighs 260g for the body and 43g for the grille.
Thanks bigly.
Also chips are "Plant-based" no matter how you cook them.
  • John_PJohn_P Frets: 2749
    I can measure the weight some 58’s at work tomorrow but I would think it’s a genuine with a replacement grill.    Nearly all the fakes I’ve seen have the wrong colour wires and printing on the connector and board, if those are right and it sounds right then it’s probably fine.
  • Emp_FabEmp_Fab Frets: 24263
    Very kind of you squire... thank you.
    Did you get a chance today mate ? @John_P ;
    edited June 2018
    I’ve just measured 3 -
    With the grills they are :  314g, 321g and 324g.    Without the grills they are 271g, 276g and 278g
    A bit more variation than I expected and I’m fairly confident they are real yours is a little lighter than mine but if it sounds ok compared to another one and the usual visual clues are right then I wouldn’t worry.
    Thanks very much John - much appreciated !
