How to fatten up a Strat?
  • paulnb57paulnb57 Frets: 3044
    X2 for the Bareknuckle Sinner, huge output on paper but surprisingly good.....IMHO every Strat should have one!....
    How to fatten up a Strat: exchange it for a Les Paul.
    3reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • sweepysweepy Frets: 4159
    Be off with you and think about your life choices ;)
    If its a Mexican Strat please throw the Bridge in the bin and buy a proper one
    Bridge pickup or the bridge itself?
  • richardhomerrichardhomer Frets: 24793
    In my experience, some Strats sound small/thin when played unplugged. Poor quality bridges (the blocks in particular) - and sometimes inappropriate woods - are usually responsible for this.
    You can attempt to compensate for these things by changing pick-ups/adding base plates, etc - but unless the guitar has a strong ‘acoustic’ low end, these things will never fully cure the issue.
  • ricorico Frets: 1220
    Oh I have a couple ;)
    What would you recommend? It's a partscaster strat - how would I identify a Mexican bridge?
    Bareknuckle Sinner
    Will investigate, many thanks!
  • DrJazzTapDrJazzTap Frets: 2158
    edited June 2018
    I was gonna say feed it pies but @darthed1981 beat me to it
    Give it a stressful job and a taste for pizza.
    Worked for me.
    Is your middle position or your neck position a nicer tone tho?
  • JayGeeJayGee Frets: 1254
  • mudslide73mudslide73 Frets: 3049
    I'm still enjoying the SSL-5 + GE-7 tbh. If I need it fatter I get my L.P. out.
  • AlegreeAlegree Frets: 665
    Easiest way is to add a 3-10k resistor in series with the bridge pickup.
  • lovestrat74lovestrat74 Frets: 2489
    Sounds interesting, any more info on this..
    Leeches treble out of the pickup by increasing the treble loss to ground through the distributed capacitance of the pickup coil.
  • crunchmancrunchman Frets: 11414
    rico said:
    Thanks for all the comments guys. I’ll try and address a few things!
    They are custom shop 54 pickups and I love the neck pickup sound.
    I have a collection of boosts/drives/EQ and they can’t get it there without colouring the tone and becoming noisy as shit.
    I’ve been using it through a cranked Marshall and Matamp, it’s not the amps that’s for sure!
    Bridge pickup is indeed wired to the tone, it tames the harshness but is still gutless.
    Is it possible to put a tele bridge pickup in a strat? I don’t mind a bit of hacking.
    Part of the Tele sound is the way the pickup is mounted in the bridge, but part of it is the baseplate on the pickup.  As a few others have said, a baseplate will help.
  • John_AJohn_A Frets: 3775
    You really dont need to throw money at the 'problem'  use the tone control, add a touch more gain to the amp, boost the mids and reduce the highs.  Plenty of great sounds to be had with weedy pickups
    I’ve been experimenting with EQ and gain - the trouble is that I’m trying to boost frequencies that just aren’t there. If I make drastic changes then it screws with the tone that I enjoy when the neck pickup is selected.
    The bridge pickup does have a copper baseplate - is this usual?
  • darthed1981darthed1981 Frets: 11674
    Worked for me.
    Certainly fuller, and it hasn't affected the functionality of my whammy bar.
    We have to be so very careful, what we believe in...
  • SunDevilSunDevil Frets: 511
    Baseplate and a tone control on the bridge
  • impmannimpmann Frets: 12649
    SSL-5 by Seymour Duncan.
    If that hasn't got enough welly for you, then your amp is bust.
