@caspercaster the pickguard came from guitars electric on ebay, I've used them before and liked their guards. I did have to file the humbucker hole to get it to fit.
Re the bridge saddles, I could tell they are wrong and I think the neck action needs amending. Do you think I just need to turn the saddles around or have I got the saddles in the wrong order, I struggled to find much about height and depth of brass saddles.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
Only issue now is I have realised the inbetween position does not appear to incorporate the bridge pickup so more meddling required!
https://i.imgur.com/OQdVPJq.jpg
Its gone from a funny looking thing to an absolute beaut....
https://i.imgur.com/eRZiDIZ.jpg
But the middle position is just neck. Not very clear from this picture but is the same as the diagram except the filtertron has the single wire and the metal shielding is acting as the ground. I added to this a single wire between the two pots as an additional ground, the black wire at the top of the picture. I have checked the conenctions and they all seem physically attached.
https://i.imgur.com/jmpJEIy.jpg
Which connection links the bridge to the middle switch as I will start by desoldering and reattaching.
Any help as usual gratefully received!
Edit I do not have the second capacitor between the volume pot and the switch as this was not on my diagram or the video I followed.
https://i.imgur.com/jooay7a.jpg
@poopot I did check the cap its not touching.
Plus, even tho’ the cap is not touching, get some insulation on there anyway!!!
