I agree that the song defines the guitar and that Metallica on a 335 will sound like Metallica. But basically wanted something that sounds as close to my strats and les paul as possible to save lugging them both around and changing guitars mid gig."
Exactly what i was looking for.
I have a Yamaha 611 which has a coil tap SD bucker in the bridge & a SD P90 in the neck, very versatile guitar & under £400 used or around £550-£600 new.
I also have a Yamaha RGX HSH which I have just swapped the pick ups on & fitted Entwhistle HB"s bridge & neck & a middle single coil.
Again very versatile sounding guitar & again well under budget.
Both will do stratty & LP sounds.
I'm also prefer to buy a guitar from a shop where I can try lots of other guitars and find the one that is right. Personally would rather pay a bit more and do it like that. Really don't get how people buy guitars without playing them first.
Cheers again all!
Rock solid Yamaha build & versatile with the coil split Seymour Duncan HB, under £600 new or there is a used one on the classifieds for £325 iirc.
You"ve probably guessed I am a Yamaha fan
are certainly, on paper anyway, very highly spec"ed hardware wise for the money & in HSS & HH with coil taps should be very versatile in the sounds department.
Under £400, so even if the sound is not what you are after, a very good platform for modding.
I am seriously thinking of giving one a try & am not put off by the name on the head stock.
”Tele, end of thread “
card !
You answered your own question with the Charvel San Dimas suggestion.Great guitars.
Pick one up second hand.Trust me you'll not be disappointed.
Caveat - I'm a major fan boy,so maybe a little biased.
A Baja tele with the s1 switch does it all. Alternatively, a tele with a neck humbucker will get most bases covered
https://www.gumtree.com/p/guitar-instrument/musicman-axis-supersport/1300476554
https://i.imgur.com/a2bMzuw.jpg
That said...
If that had strat contours on the top half it would be amazing.
