Whoever converted it, made the head cabinet bigger then a traditional head.
Lovely thing though.
Will keep you updated!
Edit: fixed the final image link which wasn't working
Would be cool to see what brand of transformers as well.
Worse than the workmanship on the cabinet, something very odd has been done with the main filter cap - it's been disconnected and mounted upside down! That implies that another one - or probably two separate ones - have been mounted inside.
Personally, I would want to check what's been done in that area - you'll need to remove the chassis from the 'shelf' board - before even turning it on, so I would advise you not to yet.
