If not then taking four may be the only sensible solution if it's not something easy like drop D.
I find them slightly impractical compared to a simple SNARK which is just so easy to use.
From left to right : Boss GE-7 EQ, Marshall Echohead EH1, Marshall Regenerator RG1, Behringer To800 Vintage Tube Overdrive ('tubescreamer'), Marshall Guvn'r II Plus, Boss CS3 Compression Sustainer, Boss Tu12H tuner.
But i want a delay and reverb, and my board is full. So i'm considering getting a Helix HX so i can just keep the TI boost and wah on the board and lose everything else.
I used all of the above (not at the same time ...) at last night's rehearsal. (Actually I've swapped out the BlackBox for a Ramble FX Marvel Drive).
JM build | Pedalboard plans
