WTB - SORTED - Attenuator 8 Ohms
HoraceBHoraceB Frets: 334
edited June 2018 in Amps £
Any about? THD, Fryette etc
Sorted :)
Cheers.
  • bazxkrbazxkr Frets: 610
    Mines not for sale but I have a Jet City Jettenuator that works damned well, ok up to about 80w or with 100w amps if you don't go much above 50% power. It benefits from 4/8/16 ohm so if you change amps you don't have to change the attenuator.
    http://www.jetcityamplificationstore.co.uk/product/jettenuator/
    They are not silly money and do come regular here/ebay etc. worth checking out to see if it covers your needs plenty of demos on YT
  • grappagreengrappagreen Frets: 1340
    I have a Palmer PDI06 that's surplus to requirements if you're still looking?
    Si
  • FunkfingersFunkfingers Frets: 14323
    I have an 8 Ohm THD Hot Plate, complete with the box and owner's manual sheet. It has not been plugged in ages. I need to check it over and research its used value.
    Be seeing you.
  • HoraceBHoraceB Frets: 334
    edited June 2018
    Thanks for the heads up chaps @grappagreen ;; &  @Funkfingers ; , much appreciated.  I would be leaning more towards the THD
  • catdogcatdog Frets: 124
    edited June 2018
    got a rockcrusher £280 delivered
