What shall we build?
RiftAmpsRiftAmps Frets: 3150
in Making & Modding tFB Trader
Got into work this morning, the sun is shining, birds are singing, slight breeze through the shop with the doors open, about to start another day building guitar amplifiers. No memos, no faxes, no 'compliance' meetings, no synergy workshops, no faff, no BS.
Basically, I'm in a glorious mood and I don't care who knows it (Hello, sailor).
Sooooooo...
I have this old output transformer sitting on my shelf, pulled from a late 70s JMP 2144, it's a Drake 783-257 also found in the Canadian-spec JCM800 2204.
The basic specs are:
Ra-a 3.4k
0-4-8ohm secondary taps (no 16!).
50w OT, designed for 2xEL34s
So, let's build an amp based around this transformer. I'd like to open up suggestions to the forum as to what spec it should be, and I'll pick the ones I like.
My only stipulations are:
- Head
- 50w EL34 fixed bias
The rest is up to you.
Once the amplifier is completed, I'd like to offer it up for a raffle on here with donations to TFB as entry fee, if that's OK with @TTony?
Suggestions below!
Rift Amplification
Handwired Guitar Amplifiers
Brackley, Northamptonshire
www.riftamps.co.uk
  • FelineGuitarsFelineGuitars Frets: 11594
    A great sounding 50 JMP/JCM  crossover - like a 2204 . master volume but with blendable normal channel and treble channels and a switchable selector for the coupling capaitors so you can select a slightly fatter sound if you are a single coil player or slightly less low end if going in with humbuckers (to reduce the woofiness)
    A great FX loop and a reverb (digital is fine)
    So you are kind of bringing together a Marshall 1987 and a Marshall 2204 but with reverb and an updated FX loop
  • SporkySporky Frets: 28153
    It should have blue sparkly tolex, white piping, and black grillecloth (if you put such onto heads). All fittings should be chrome. The control plate should be black with white text, and it should have white chickenhead knobs.
    Single channel, master volume with reverb and post FX loop....
    Oh and the raffle idea is both generous and a fab idea....thanks!
  • hywelghywelg Frets: 4303
    Was that to fit the mismatched 6.6k OT like Aynsley's 2144?
  • RiftAmpsRiftAmps Frets: 3150
    Yes, but it’s not 6k6 ;)
    Rift Amplification
    www.riftamps.co.uk
  • DrBobDrBob Frets: 3006
    What my learned friend suggested above sounds quite frankly marvellous !
    Great gesture re the raffle, I'm in
  • WezVWezV Frets: 16668
    very interested in this raffle idea... I don't mind what the amp is too much, but if we can arrange it so I will the raffle that will be great!  ;)
  • normula1normula1 Frets: 640
    Rather than the obvious Marshall influenced design, how about something more clean with just a touch of drive and configure the output stage to cathode bias with perhaps reduced voltages too so that you don't have to blast the room out to get it to that slightly driven sound.
  • impmannimpmann Frets: 12665
    Howabout a HiWatt influenced design?
  • MtBMtB Frets: 922
    A Sound City 50 Plus-alike with great loud cleans but no flaimin' hiss. Great pedal platform and the SC power reduction switch - one that really does cut the volume down to bedroom friendly levels.
  • ThorpyFXThorpyFX Frets: 6131
    An ac50 with more gain from the preamp
    Adrian Thorpe MBE | Owner of ThorpyFx Ltd | Email: thorpy@thorpyfx.com | Twitter: @ThorpyFx | Facebook: ThorpyFx Ltd | Website: www.thorpyfx.com
    I'm listening...
    Rift Amplification
    www.riftamps.co.uk
    RiftAmps said:
    I'm listening...
    Just that... a HiWatt based circuit. Same tone stack, same gain structure... perhaps an effects loop.
    I know absolutely nowt about how a HiWatt differs from a Marshall electronically except that one is vile and from Bletchley, the other sounds like Angels (or Angels on crack if the gain is dimed).
    A dual channel DR103 that has all the awesome cleans of the DR103 with an additional overdrive channel?
    Maybe on a 2x12 format in a chassis that doesnt weigh more than the moon?
  • vasselmeyervasselmeyer Frets: 3672
    Something Voxy with a gain control, a master volume and three-band EQ. No reverb but a post EQ FX loop with a mix control.
  • andy1839andy1839 Frets: 2197
    Something along the lines of a Matchless Clubman but more useable for people who play at home.
    Treble, middle, bass, presence, gain, reverb, fx loop, master volume and a variable footswitchable solo boost.
    And a half power switch.
  • andy_kandy_k Frets: 818
    i'll be in the raffle, all i can offer
    Ok guys, thanks for all of your suggestions so far.
    I'm really enthused by the non-Marshall ideas, especially the HiWatt and Vox stuff. I mean, is another modded-Plexi type really needed when we have the opportunity to do something different?!
    I think that's the route we'll go down, it's certainly got me really excited about this project.
    So, preliminary specs are:
    • Single channel Hot-rodded Vox-inspired preamp section with Gain, Treble, Mid, Bass, Master, and Presence(or Cut?) controls
    • Hiwatt style 50w OP section, with switchable GZ34/SS rectification
    • Series FX Loop with level control
    • Some form of outrageous boost to melt faces
    I'm going to start the circuit design shortly :)
    Rift Amplification
    www.riftamps.co.uk
  • interstellarinterstellar Frets: 486
    valave driven acoustic amp
    Damn @RiftAmps that's left me drooling. How about a build thread?
