This little box of fun replaces an expression pedal with an 8 step sequencer, with sliders to set the position for each step.
It means it can do things with more precision than would be possible without a lot of practice and some serious training to match the higher speeds
I've tried it out with my Count To 5s, BitQuests, Particle, Grazer and Rainbow Machine and it adds another dimension to all of them when it comes to the noises they can make.
It's one of those pedals that makes you think "I wish I'd bought one sooner".
"I'll probably be in the bins at Newport Pagnell services." fretmeister
Might I suggest that a Source Audio Reflex might float your boat? Expression pedal with onboard LFOs which you can adjust with the pedal, and it can control a whole load of things at the same time.
Someone else mentioned that, so I might have to add one to my wishlist.
My only fear with this is that the way it works might be putting extra voltage through the pedal and therefore might blow it up.
What a great idea - I have a Pitch Fork but hadn't got round to trying it yet - I also have a Miku plugged into a feedback looper
Just had a quick blast and it's great fun !
