It also weighs as much as a small car.
Worst reverb I've heard in any amp and the clean sound was flat and uninspiring.
The odd thing is that I love the Trem-o-verb, which you would think is similar but bigger since it's based on the Dual Rectifier and the Rectoverb is based on the Single Rectifier. No... the Trem-o-verb is one of my favourite amps ever, but I would need paying before I would use a Rectoverb - they're totally different.
Of course the problem with the Trem-o-verb is that it weighs as much as a large car .
Worst amp ive ever owned.
The Nomad also has a solo boost, which the DC-5 doesn't - but you can use the DC's graphic EQ as a boost.
Yes, supposedly the same pre amp section but different power amp stage. 50w 6l6 (or EL34) v 25w el84.
The Trem-o-verb might be the right Mesa for me, but I’ve always been scared off by the weight and size. I really should try one, though.
