System: | 2-way Active Nearfield Monitor |
Frequency Response: | 41Hz - 21kHz |
Max SPL 1m, pair (IEC Long Term): | 118dB RMS |
Max SPL 2m, 5.1 (IEC Long Term): | 119,5dB RMS |
Input level for 85 dB SPL @ 1m (+4/-10): | -12dBu RMS / -28 dBu RMS |
Input level for max peak SPL (+4/-10): | +16dBu peak / -1dBu peak |
Power consumption: | Idle: 25W / Max: 200W |
Amplifier power: | Tweeter: 100W / Woofer: 100W |
Resonance Frequency: | 49Hz |
Internal Cabinet Volume: | 9,5 liters |
Principle: | Bass reflex |
Crossover Frequencies: | 2200Hz |
Crossover Slope: | 24dB/oct |
Tweeter: | Esotec 28mm soft dome, rear chamber, Magnetic fluid. 4 mm die-cast alu front, |
Woofer: | 17cm, 75mm pure alu wire voice coil, One piece molded polypropylene cone |
Weight: | 11kg |
Dimensions (WxHxL): | 217 x 338 x 321mm |
