Unlike guitar, the sound coming down the jack cable is pretty much fine, which means that the tone really does come down to the sound of the bass, and the way you play it. Plugged into a decent D.I. input with a suitable input impedance and enough headroom, you'll capture the sound of the instrument. Anything beyond that comes down to taste.
When I'm working with a DI recording, I'll usually EQ it similarly to what an amp would do - broadly speaking, roll a low pass filter around anywhere from 3-6k depending on what you hear, tidy up some swimmy, tubby midrange around 300 hz and find a little meat down below 150 to boost a couple of DBs. Then compress it to even things out. Again, it just comes down to taste. Slow attack, release slow for rolling basslines and faster for more aggressive stabby playing. 3-5dB at 3:1 ratio is a good starting point.
From there, it should basically sound like a bassline and you can move on. Often, a bit of saturation or overdrive can help once other things start going on the track that obscure the midrange of the bass (counterintuitively, bass is still a midrange instrument - how it sits alongside vocals and guitars etc totally defines it.) How you overdrive things is totally down to what you have at your disposal - there's a million ways to do it!
Bandcamp
Spotify, Apple et al
I think I have a copy of Guitar Rig somewhere, never used it though.
Just to re-iterate though what I do is record in Audacity. I just want to get the best sound possible for recording purposes. Its only for home stuff and messing about on youtube for my mates to laugh at although Ive written 18 songs in the past year or so. Most of them complete shit of course but I am starting to take it more seriously.
Cirrus. I understand some of what your saying but its all a bit technical. Most of the stuff you talk about such as low pass filters frequencies etc I have seen in Audacity but not really sure what they do or how to work with them.
I think I am getting closer to achieve the sound I want though. It was much better when I put it through the amp so maybe that little Pre amp box might just do the trick.
I am very interested in finding out more about frequencies and filters though as I have found my trial and error stuff clashes. I dont play with backing tracks much anymore so might put down a track with Vocals, acoustic guitar, lead and Rhythm guitar and Bass now and the other day even a keyboard (although I really cant play that) and sometimes it sounds like a big muddy mess. Ive just worked it out by using the equaliser in Audacity to knock off the lower end or boost mid range on an instrument etc but its complete guess work and trial and error. It seems like a black art. Who Knew? All good fun though.
The amp is effectively a preamp if you're not using the speaker.
Reaper is great but not everybody gets on with it. Download the 30 day trial of Magix Samplitude ProX 3. If you DO get on with it you can get the free Samplitude Pro X Silver. Limited to 8 tracks but can run plugins etc.
BTW, Son informs me "they" have just bought a Jazz Bass. Anything dad needs to be prepared for?
Dave.
Our second demo was in the same place with a different engineer. I convinced him to let me use an amp (my AOR30) and a line-out from that went I to the DI into the desk. It sounds so much better.
As regards Reaper, I have heard about it and it sounds great but to be honest ive spent a couple of years getting my head around Audacity and for what Im doing for now its ok. I do actually have Cubase LE on this laptop which I Got with the M Audio interface but ive not played with it yet.
Im pretty technical to be honest as I work (Well I am semi retired) in IT but its the last thing I want to fart about with when it comes to music as its all about having fun, drinking and making a din.
Despite my advocating DI as a fair option, my favourite bass sound = Ampeg SVT into an Ampeg 1x15 cab for rock, hard rock, anything short of metal or funk where the speed of a 4x10 is preferable. The 1x15 slows down those transients, thickens up the sound... love it.
But you need to have the ability to play bass through a loud amp, a room that isn't lumpy in the bass end and a good mic to pick it all up.
Bandcamp
The next test is just the cable into the input of your chosen interface box(es). Expect a steady hum. Generous helpings of hiss suggest either lashings of gain and compression raising the noise floor or shite cables.
Sounds as if the first engineer literally plugged the bass guitar into the mixing console but applied no outboard compression. In the digital recording age, there is no tape saturation or head bump contributing to the overall dynamics.
A partial solution may be to run the amp louder than you would normally - assuming it doesn't distort or overload the audio interface - since that should increase the signal to noise ratio. It won't do any harm to the amp.
Not played around that much with the pickup volume controls to be honest. I cant really figure out which is the best setting for them but thats worth a bit more exploration. I have to have the Amp volume pretty low when playing through either interface otherwise it blows it right into the red even with the gain right down if using the M Audio Interface. The G3 is not as easy to control anyway.
I think its ok though. I was messing about last night and trying to come up with a track that was Bass dominated and it sounds alright. Well to me it does. I ended up making it into a song and recorded it. I dunno if I Dare post the results on here though,
The signal level mismatch can be corrected either by using the Signal Pad attenuation in the M Audio box or by feeding the signal between the amp and interface on a 1/4" jack to Phono (or XLR) cable.
On the Zoom G3, it may help to make a few edits in the Global Settings menus.
Here, I entirely agree with you. "It's just da bass, innit?"
Bandcamp
