The other part still stands though - Fender are pretty good for quality control even at the low end of the range. A lot of people look down on Fender acoustics, but personally I think they're fine.
Personally I'd take a Fender over quite a lot of the supposedly more "approved" acoustic guitar brands, at least until you start to spend fairly serious money.
It’s also worth bearing in mind that Yamahas usually have slightly narrower necks and string spacing, although I’m not certain about that model.
At that price point I would also take a look at the Sigma DM ST.
I quite liked the only Fender acoustic I have played, you might want to consider getting that set up by someone who knows what they are doing.
My first point is serious though, I was about 40 when I started playing guitar and went through the whole "it's the guitars fault" that everything I played sounded shite and was really difficult. Even though my early guitars sounded great when other people played them I kept buying more expensive guitars thinking things would get easier. This is true up until a point but the truth is you need to practice loads! Don't make the mistake I made of blaming the tools!
BTW - ten years later I've got a high end custom shop acoustic and I am still shite! ;-)
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
