Ivison Guitars '59 DC Model - Build Thread
  • DanielsguitarsDanielsguitars Frets: 3261
    one of the reasons i use hide glue for a fretboard and neck is i can get it apart easily, i started with titebond and still use it for certain things, I've had good results building with with both inc acoustics
    Can't really say if one sounds better though
    www.danielsguitars.co.uk
    (formerly customkits)
  • IvisonGuitarsIvisonGuitars Frets: 6838
    edited June 2018 tFB Trader
    WezV said:
    I thing you could sell that idea to stew-mac.  Looks like a great solution.
    as above, I often use a trapeze to hold the strings.  But I really like the addition of the bolts for marking position
    Cheers @WezV! Wouldn't that be sods law, the 10 minute make bridge placement contraption earns me more money than the guitars!
    @Jez6345789 No I use Titebond Original. Perhaps strangely, for someone so obviously anal about all things vintage, I don't buy into all the 'the tone is in the glue' BS to be honest, I think there are far greater contributing factors to the guitars tone than that
    http://www.ivisonguitars.com
    (formerly miserneil)
  • WezVWezV Frets: 16547
    Its like a lot of stew-mac jigs in that it’s only useful for one job and could be made fairly easy... but many would still buy rather than make
  • SteveRobinsonSteveRobinson Frets: 6914
    There is a lot of satisfaction in making ones own tools but I estimate how long they would take to make, calculate what I could earn in that time doing setups and refrets, and order from Stewmac!
    I'm the same but we have an engineer friend who makes our stuff and i had another friend make my radius jig in exchange for wood and stuff, win win i say
  • Jez6345789Jez6345789 Frets: 1756
    Neil
    i am with you on the glue front and I think it’s mostly come about due to the Les Paul forum a few year back banging on about all the things wrong in reissues and glue was an easy corporate win and box tick and everybody changed from titbond although when I watch videos it always seems to be some polymerised hide glue don’t see a lot of hot glue pots.
    tonally I see it in my mind as an idea but hear it I am doubtful
    Neil
    as I've used both I'll state exactly why i use hide glue, I'm not interested in snake oil or bs either, my acoustics both sound good with titebond original
    I put together a les paul and while it was good i thought it could sound better so i took off the fretboard and took the neck back out, i changed the neck angle slightly and put different frets in, i put it all back together and it just came alive for me, this is what's good about it, i can change things easily and experiment
    Until you've used both you can't say it's all rubbish, same goes with all guitar making, you have to try it rather than read about it imo
    Both titebond original and hot hide glue dry very brittle and work very well. Anything that dries rubbery should be avoided.
    what I don’t like is when people go on about the benefits of Hide glue, then it turns out they are using the pre-prepared stuff that is liquid at room temperature and has a long shelf life.  Lots of additives which take away the real benefits of hot hide glue
    i use the hot hide granules that you soak in water and i like the fact i can make small quantities enough for what I'm doing and it stays fresh until used, i have got a glue pot but it takes ages to heat up so i use a camping stove on very low heat to bring up to temperature, i can also thin it down if i want, it's something you have to get used to using
    I don't use clamps on my fretboard but a thick rubber band that i wind round, it's quick and does the job really nicely especially with a radiused board
    I'll start a build thread soon to show how i do some of my building, a pic is easier to understand
    If you just need a small amount you can heat hide glue in a microwave.
    Thanks Steve, that's interesting but i haven't even got a kettle in the shop yet and I've already run out of space, gotta find room soon though or nothings getting made
    As a kid I remember my grandad had a bean tin for the glue, placed directly on a log burning stove for a minute or two
    miserneil said:
    ...and position it under the strings and measure the scale length. With this jig I can adjust the bridge until I get the intonation spot on and I can also make sure the strings are positioned perfectly over the P90 like so:
    Once i've checked, double checked and triple checked the intonation and position, I screw the bolts down (which I have ground to a point)...
    I think you need to line up the bridge to that the strings pass over the centres of the rear holes in the bridge, where they will emerge when the guitar is strung. You seem to have them centred over the front holes? (I.e shift the bridge to the bass side a touch.)
  • GSPBASSESGSPBASSES Frets: 2335
    I agree, if you line up the strings as shown in the photo on a wrap over bridge when you string the guitar up the strings will be over to the treble side by a few millimetres. It is best with your way of doing this to line everything with the holes in the back of the wrap over bridge as  @SteveRobinson said.
    @SteveRobinson @GSPBASSES Thanks for the advice chaps, totally agree and I do just that, this photo was taken part way through the process, there was still plenty of fine tuning to be done
    Loving this thread
  • meltedbuzzboxmeltedbuzzbox Frets: 10337
    Loving this thread
    +1
    I check daily for picture updates
  • paulnb57paulnb57 Frets: 3044
    +2 Me too!
    edited July 2018 tFB Trader
    @meltedbuzzbox @paulnb57 Thanks for the support chaps! More Thursday eve
    Thursday evening.  arrrrrgh
    two more sleeps then lol
