Mojo Pickups Mojotron Neck Position (Price drop)
LamonpLamonp Frets: 5
edited May 2018 in Parts £
Mint condition neck position Mojotron from Mojo pickups in the UK. It will drop right into a standard filtertron mount and comes with two woodscrews. Looking for €70 plus postage (£60 plus postage)
Full details below:
Description
Mojotron vintage Filtertron sized.
Bright and twangy like the originals.
Wound with 42awg wire and with a large 1/4 inch Alnico 5 bar magnet.
Neck 4.2 (1.52H) and Bridge 5k (2.25H)
The covers are historically correct and based on a vintage Filtertron cover.
The base plate has “ears” as standard on this model.
The covers are not soldered to the base plate, as per the vintage pickups.
Pictures here:
https://reverb.com/item/12018715-mojo-pickups-mojotron-2017-chrome
  • LamonpLamonp Frets: 5
    Bump
    Bump part deux!
  • johnljohnl Frets: 2011
    Will this fit a P90-sized hole?
    Hi Johnl. I'm really not sure. if you want to take some measurements of your P90 pickup and send them to me I'll do a match against the mojotron.
    Bump!
    Bump!
    Bump
