Magnetic Effects White Atom V3
Magnetic_EffectsMagnetic_Effects Frets: 135
edited October 2019 in Made in the UK tFB Trader
Updated version now available!
Now with added active Bass eq and tweaked eq response.
The White Atom is a fabulous, versatile hybrid Silicon and Germanium transistor fuzz. A wealth of tones from vintage style overdrive to velcro like saturated fuzz are available.
There are five controls: Volume, Gain, Treble, Bass and Texture. The Texture control changes the feel and response of the fuzz. When used in combination with the Tone and Gain control many shades of fuzz and drive are availablbe. Everything from focussed, tight through to splatty and  choked.
The pedal has a high input impedance and a low output impedance. This makes the White Atom, unlike many fuzz pedals, compatible with buffered bypass pedals as well as pedal switchers and wireless systems. It also allows the pedal to interact well with modulation and time based effects.
FEATURES:
- Volume, Gain, Treble, Bass and Texture controls
- High input impedance and low output impedance
- 9V DC centre negative adapter operation
- True Bypass switching
- Reverse polarity protection
- Top mounted Jacks and DC socket
- Individually selected and tested Silicon and Germanium transistors.
http://www.magneticeffects.net/white-atom/
