After a lot of prevarication, I'm trying to pull the things that I already own into a basic home recording set up, but I'm not sure what I need to add to have an effective, minimal, low cost set up for (mainly) acoustic guitar and vocals.
What I have, so far:
Nice guitars and amps. (J45, ES-125, Gretsch Country Club and a Larrivee parlour for some tonal variety)
Good Macbook and a legit copy of Logic X that I have still only scratched the surface with.
Decent monitors
Apogee One for Mac
SM58
Mic stand
A little Zoom H2n recorder
Quiet recording spaces.
Can this stuff be cobbled together into a half decent set up to record guitar and vocals? I'm only hoping to spend a few hundred pounds more (less if I can) but I'm not sure what's best.
I like the SM58 for vocals and I think it might be as much as I need. The built in condenser mic on the Apogee has given me ok-ish results recording the guitar and vocals together but that seems good enough for a guide track, but recording both through the same mic has obvious limitations. I guess I need a dual input audio interface and another mic for the guitar as a minimum... and, I guess, another mic stand.
I know it's a form of insanity, believing that you can do good work on truly limited tools, but I keep coming back to Justin Vernon recording 'For Emma...' and Bruce Springsteen recording 'Nebraska' on not much more that I currently have. I guess you could take that as my inspiration.
So... how mad am I?
Do you record the singing and acoustic at the same time? I'm probably not the best person to help as I'm not very good at acoustic guitar, singing, or recording (especially not any of these simultaneously) but I'd have thought a two input usb interface would do the trick. You could then use either one input for vocals and one for guitar (either mic-ed or pickup into jack) if doing both simultaneously, or if you record guitar separately you could use one input for a microphone and one for a pickup and blend the two together then. That's what I did recently for an "acoustic demo version", though my pickup is single coil so had some high pitched humming which meant I effectively put an eq block on the higher frequencies and the two tracks then blended rather nicely as it was lacking bass through the mic anyway.
So for that I guess you'd need to buy a 2 input interface (or another single input one to go alongside your existing one) and a microphone for the guitar - I assume people who like acoustic music are more fussy than I was for a microphone (I used a vocal mic...) so a nice condenser might set up you back a bit I guess.
Ah thinking about it - the mic stand! If you do record both at the same time through mics, you may need an attachment for the stand to put the acoustic mic on at the required height. Or if you do them separately, you'll need the stand to be a boom mic stand to tilt it to the right height (or again, get the attachment for it so as not to need to move it all the time)
soundcloud.com/thecolourbox-1
Looks like the zoom is a handy tool...its has 2 inputs yes?....so you can do vocal mic and DI accoustic guitar ?
https://twitter.com/spark240
Reddit r/newmusicreview
https://www.guitarguitar.co.uk/product/13111115170232--rode-m5-microphone-matched-pair?gclid=EAIaIQobChMIy7nc34OL3AIVRrDtCh1vCwT8EAQYBCABEgKr1PD_BwE
I think being able to record in stereo is worth going for. It opens up your options without overfacing you with choices.
Taking the Zoom tracks and importing them into your DAW is fine if they're the starting point for your project and if the performance is either in time or you don't care and are happy to follow the timing you recorded at/to.
You definitely don’t need a Thunderbolt interface. USB is more than enough.
Feedback
