Echoplex preamp kit build troubleshoot question
Evening all,
I built a Fetoplex, echoplex preamp clone kit this morning, it works when the pedal is engaged but no signal is getting past when it’s off.
ill retrace my steps, but if anyone has any ideas that would be great
Cheers
Toby
  • FunkfingersFunkfingers Frets: 14324
    Probably, a simple oversight. Needless to say, remote diagnosis would be greatly aided by photographs of your actual wiring.
    Be seeing you.
  • lasermonkeylasermonkey Frets: 1940
    I'd guess it's a switch wiring error.
    My wife asked me to stop singing Wonderwall.
    I said maybe.....
  • Adam_MDAdam_MD Frets: 3420
    Most likely this.  Your input or output is bleeding to ground do you have a multimeter?
  • skippy76skippy76 Frets: 615
    Thanks guys, I’ll start with the switching and work from there
