neck pick up to pair with a JB?
ReverendReverend Frets: 4974
Any ideas on what would make a good match for the JB in the bridge? Looking for something for a Les Paul and for an LTD Viper.
Thanks
  • guitarfishbayguitarfishbay Frets: 7953
    edited July 2018
    What kind of neck tone do you like?  Do you want it brighter/glassy or do you want it deeper sounding?
    The two main classic pairings are Jazz - which will thin out the neck position, or a 59 - which has more low end weight to it and would be closer to a typical 'Gibson' type of tone, at the expense of tightness.
    If you hate low end flub the Jazz is the way to go with the JB.  I'm very picky about when I like the Jazz as sometimes I feel like it can work against the characteristic of a guitar if it's quite fat sounding naturally, but it depends on what you want.
  • FunkfingersFunkfingers Frets: 14321
    For a Les Paul type guitar, I like either an open SHPG-1N Pearly Gates or a covered SH-1N '59 with an Alnico IV bar magnet. (The nearest Duncan production line equivalent is the Saturday Night Special. The Whole Lotta Humbucker is another interesting possibility.)
    For an SG, I would try a humbucker-sized P90 or one of Oil City Pickups' naughty Winterizer II Firebird-alikes.
    Be seeing you.
  • AlegreeAlegree Frets: 665
    JB in an SG was hands down the worst tone I've ever had. Keep it away from mahogany SGs at all cost.
    +1
    In fairness, the LTD Viper comes in various guises from bolt-on beginner level to an Epiphone killer and near Gibson rival. The inexpensive models probably don't have very much mahogany in them.
    DISCLAIMER
    To anyone who wonders why I have name-checked OCP but not mentioned Alegree, this is for the simple reason that I have yet to experience any of the latter's products.
    Be seeing you.
  • SteveRobinsonSteveRobinson Frets: 6914
    Another non-fan of the JB here. I think it's quite shrill and needs a lot of gain to smooth it out. OTOH, some people seem to like it.
  • professorbenprofessorben Frets: 5105
    Love the JB in pretty much anything I’ve put one in.
     I found the Dimarzio PafPro to be an outstanding neck pickup in an SG type guitar.
    Depends if you can live with the mid match of pole piece types tho.
  • SchnozzSchnozz Frets: 1926
    I would say Jazz for a Les Paul and '59 for a Superstrat, but I probably wouldn't put a JB in a Les Paul
    I think the PAF/Super Distortion Combo that Dimarzio make is a better fit for an LP (IMO).
    Reverend said:
    JB in the bridge ... LTD Viper.
    This combination suggests the -400 Series model. The stock neck position pickup should already be a Duncan SH-1N '59 - albeit displaced towards the bridge by the twenty four fret neck.
    Be seeing you.
  • ICBMICBM Frets: 71956
    ‘59.
    I’ve tried the Jazz and the Pearly Gates, and both are just too thin.
    The JB is a very marmite pickup, but if you want that aggressive, slightly nasal midrange squawk it’s fantastic. For forced harmonics there’s really nothing quite as good... but it will not do more subtle tones. It’s not meant to.
  • fastonebazfastonebaz Frets: 4065
    A 59
    No other contenders.
  • OilCityPickupsOilCityPickups Frets: 9982
    ICBM said:
    ‘59.
    For me the same, its somewhat of a one trick pony ... but if you like that trick ... great.
    Interesting story: Jazz/Blues is an odd title for a pickup of this character ... the story goes it was initially built for 'Jeff Beck' but for some reason his name doesn't appear on it .... they do an EVH pickup that is apparently 'definitely' not an Edward Van Halen too!
    Perhaps I should use the name 'STTPUOTBABEC' for a popular one of my PAF style pickups: Similar To The Pickup Used On The Beano Album By EC'  :-)
  • Philly_QPhilly_Q Frets: 22516
    I know Jazz/Blues is the "official" story, but never in all my years have I ever heard anyone actually call it that.  For many years loads of dealers would call it the Jeff Beck pickup - still do occasionally - despite SD's protestations.
    I don't know if SD ultimately clamped down on the "Jeff Beck" terminology, or if we all finally got used to calling it the "JB", but whatever it is it's a remarkably popular pickup.
    As for the EVH, it stands for "Evenly Voiced Harmonics".  Obviously.  Nothing to do with that Dutch bloke.  It's now called the 78 model, I don't know if it was ever officially called the EVH.
    The early 'JB's were also seem to have been a very different formula to the modern ones ... did a some digging on this and measuring old pickups a few years ago.
    To the OP: something PAF like for the neck ... a 59 if you are going Duncan.
    That was oft-discussed in the old days on the Bare Knuckle Pickups forum - every time someone mentioned a JB someone would chirp up "Ah, do you mean the original JB, or the current one?".  I have one from around 1985, but I think it's still the "new" formula. There can't be many originals around.
    I agree about the SD '59 neck, I didn't like the Jazz, too bright.  That said, I've always been curious about the Alnico II neck, but never tried one.
    The originals were more like what we'd call now 'Custom Shop': lower output ... less scooped and nasal mids. I have all the spec from the last time I encountered one, and in fact it gave birth to my 'Dirty Secret' humbucker found here
    I like the custom 5 for a bridge LP type.
  • PhilKingPhilKing Frets: 1473
    I have an original JB (the one Tim Mills at BK measured to see what the old spec was).  It's 14.7k and has asymmetrical windings, though I don't remember the split of each coil.  I have it paired with an original SD Pearly Gates in an Epiphone JB (as in Jeff Beck), limited edition Les Paul, with the wrap around bridge.
    Exactly the results I got ... it was wound with 43awg wire instead of the 44awg of later ones ... leading to less of that mid compression and a more open and less nasal tone.
  • ReverendReverend Frets: 4974
    The Ltd viper I think is a 300 or something. It's very old (one of the first that came out) and has those passive emg things. I like the jb in mahogany as they have plenty of oomph with out the flat harshness of most high output pickups. I tune to c and play loud. I dont care about how things sound much when playing at home because the is mostly irrelevant. How things sound on stage is the thing really. The other guitar is an lp studio rhat plays well but sounds a bit weak compared to my others. I have a in sat around and waiting to be used. Got a Sd with a sticker that says 59bg which i presume is a 59 bridge.
    I have one that days #2 al v and has a small paf black sticker as well. It has been measure at 8k.
    I think for the type of music you play and the sound you're using, anything even roughly PAF-like in the bridge is going to be too low-output and not middy enough. I find the '59 bridge a bit thin and lacking punch even though I don't use anything like that sort of sound and I love the '59 neck...
    I would be looking at 10-12K upwards (yes I know the DC resistance is only a rough indicator!) and probably not Alnico II, I find that too soft-sounding unless the winding is even bigger - the Duncan Custom Custom (14.5K) is the only Alnico II bridge pickup I like, but may also not have enough definition for you.
    I don't think the JB/'59 combination is a bad choice for what you're describing even though it is very much not in fashion now.
    [Slight thread diversion] The same is true of V30 speakers. No longer very fashionable, not good for more open, vintage-style tones with low-powered amps - but still a great choice for harder rock sounds at gig volume (especially down-tuned), they have a punch and aggression that just works for that.
