24567
  • meltedbuzzboxmeltedbuzzbox Frets: 10337
    gringopig said:
    Yeah, it does depend on price. I think mine would set you back significantly more than I paid for it 4 years ago now.
    I can see a custom shop re-issue on Peach but it's close to what you might pay for an original. How much should an untouched 63 or 64 go for - in sunburst?
    I think you’d be looking at 3-3.5k now
    I would have thought nearer 5k?
    Or have I been looking at daft dealer prices?
    benecol said:
    As for the trem the Staytrem collet and arm is a great upgrade.
    Absolutely the best upgrade you can make on a Jag or a JM.
    The arm sits too high for me and the custom shop system works a lot better. Imo and all that
  • GavRichListGavRichList Frets: 7145
    No, you’re maybe right... I’d certainly expect over 4 for mine
  • benecolbenecol Frets: 398
    Ooh - I wasn't aware the Custom Shop trem was any different; go on...
  • GagarynGagaryn Frets: 1553
    Stayterm arm sits same height as the Fender arm so long as it is pushed properly into the collet which many people don't - it's a tight fit.
  • earwighoneyearwighoney Frets: 3491
    Maybe just get a tattoo of Kurt Vile instead?
    It stays in place like the staytrem system but isn't raised 5 cm above the scratchplate. Has a nicer feel too
  • gringopiggringopig Frets: 2648
    edited July 2020
    edited July 2020
    If you find one you’re interested in, float the link here - I’ll try and spot anything obvious
    edited July 2020
  • Grocer_JackGrocer_Jack Frets: 258
    I'd say you should be able to get a sunburst for £3K private sale or non- London dealer
    I have an early 62, and in all honesty it’s everything I could ever want in a guitar. The early early 62s have a slab neck, which adds a fair slice of warmth / thicker low end. Also has black bobbin / flat pole pickups, again warmer than you might expect; certainly not the shrill jingle jangle weediness of the reissues. There are actually a whole bunch of tiny changes to the Jaguar line that help authenticate the years; there used to be a brilliant website called Jim Shine, but it seems to be defunct.
    Wiz for this. I have a 64 refin in sonic blue. I've also had various reissues. A good pre- CBS Jag is not particularly bright, except with tone and volume maxed out, and will have quite a deep low end and a nice flat eq that sounds great with Tweed amps or drive pedals that add some mids. They're not all about cleans (tho the cleans are great) and you can get some huge tones with quite heavy drive and fuzz. They can weigh a ton as well so that might be a factor.
    Ok maybe £3.5K. I'd go for a nice refin myself.
  • jimmyguitarjimmyguitar Frets: 2464
    I have an original sonic blue 62 for sale and would prob take £5k for it. Sunburst should be £3k max.
    edited July 2020
    gringopig said:
    I saw that one. Looks nice  but maybe not for me as the price reflects a custom colour  and rightly so. A couple of weeks should see the result of my interview and if positive I will want to celebrate!
    Marlin Sidewider - Plan B.
    edited July 2020
    edited July 2018
    gringopig said:
    Those are going to take off. Mark my words. They may scoff now and throw bruised fruit straight at your face with vigour but remember, we knew first!
    If Marlin Sidewinders become valuable collectors pieces then I’m giving up and buying a flugelhorn.
    edited July 2020
