Overwinding stratocaster pickups
jaymenonjaymenon Frets: 814
edited July 2018 in Making & Modding
 What happens sonically as you progressively over wind a pickup?
 I believe the output increases -  but what does it do to the actual sound?  Does it make it more mid-range heavy?
  • Adam_MDAdam_MD Frets: 3420
    You tend to lose some highs in my experience.
  • paulnb57paulnb57 Frets: 3053
    I have a BK Sinner at the bridge on a Strat, I can't say if its more middly, but its certainly a fuller sound compared to a standard Strat bridge, but not excessive drive as the resistance would suggest (21K)
    I think it also depends on wire gauge and magnet type......a grown up will be along shortly.......
  • AlegreeAlegree Frets: 665
    Interestingly, while humbuckers gain predominantly mid range, single coils seem to gain predominantly bass as overwound. I assume that's just because the frequencies added (literally or relatively) fall in a  humbucker's mid range which is equivalent to a single coil's bass range. And as others have already said, treble loss too.
