Although Gotoh, Ping or Jin-Ho machineheads would not be out of place on a Mexican-made Fender electric guitar, if they have any legend on the gear housings, it is either the CBS-era script or just the reversed F.
Spaghetti script engraved on the circular inserts is a new one on me. Chender.
Pretty sure they're fake then, and almost certainly not an upgrade on what Fender put on the Squier Affinities.
Bear in mind that the description is incorrect though - they need a *10mm* hole, not 8mm. If your headstock has 8mm holes you will need to bore out the back to fit them, which is a slightly tricky job without the right tools.
