Patina on brass.
does anyone have a good recipe for getting a patina on brass?
I’ve Googled “aging brass” and all I get is pics of my mates mum!...
  • BluesyDaveBluesyDave Frets: 410
    Yup, put your greasy maullers all over it.....that'll do it.  Might take a year or two   ;)
    No Darling....I've had that ages.
  • GagarynGagaryn Frets: 1553
    The usual vinegar fumes method should do the job.
  • telehacktelehack Frets: 93
    If we're talking bridge saddles, I wouldn't even bother. I put new brass saddles on recently and just resting your hand on the saddles for palm muting will start to discolour them in a matter of days or weeks.
  • WezVWezV Frets: 16546
     vinegar  should give it a start.  It may make it look cleaner first
  • poopotpoopot Frets: 9098
    Yep, cleaner than when it went in!
    will give it to the yoof when he gets home from school, he seems to be able to reduce a brand new set of strings to rusty wire within a day so I’m hoping his greasy hormonal hands will darken up the saddles!...
  • CasperCasterCasperCaster Frets: 760
    As others have said, brass will discolour quite quickly once sweaty hands have been on it, so give it a couple of weeks before trying anything else.
    Cold patination techniques are commonly used in the restoration/ reproduction of antiques. There is a business near me (Bury, Greater Manchester) which sells these products, assuming sweat/ time don't give the desired results:
    https://www.restoration-materials.co.uk/index.php/metal__marble-antiquing/?k=1906:37::
  • GassageGassage Frets: 30826
    Vinegar does work. Interestingly if you put the item in vinegar with salt it will remove all patina.. but exposed to vinegar fumes will encourage a gentle patina to develop.
    A stronger acid acid will do the same job but more quickly. Nickel and copper the same.
    I do agree that brass will naturally tarnish quite quickly with sweat - just like copper coins do when handled.
  • SargeSarge Frets: 2370
    Some brass saddles come clear coated, this may need removing before any tarnishing will appear.
    I take off the clear from old Matsumoku brass parts by just leaving them soaking in standard thinners for a couple of days the a quick rub with a rag or soft brass suede brush.
