*SOLD* F/S Morgan SW22r
teiscoboyteiscoboy Frets: 28
edited September 2018 in Amps £
Stunning Morgan SW22r in classic twilight finish for sale. Excellent condition.
£1400 ono
https://www.flickr.com/photos/153573040@N03/shares/5yr13K
The Bass Emphasis switch changes the center point of the mid frequencies allowing you to get even more bass out of the amp. The bright switch is designed to bring in enough top end for even the darkest guitar but without adding any ice picky highs
If you're a guitarist who plays clean to overdriven tones and you need an amp that can handle anything from a smoky club all the way to those venues where you need binoculars to see the stage from the back of the crowd then this head is a great choice.
Here's what Morgan have to say about this combo
The SW22R offers the same tonality of the SW22 including its ultra-sensitive pick attack and singing sustain. The SW22R reverb is also run parallel to the original tone stack. This means when the reverb is not being used it is totally out of the circuit unlike most other guitar amp reverbs. Intentionally designed to be the loudest cleanest it could be with 2x6V6s it is still capable of producing a warm compressed natural overdrive. The SW22R utilizes a special level control. Its job is to control the amount of gain available in the power section of the amplifier. You will notice after about 3 o’clock on the level control you are adding overdrive to the power section. This allows you to use the level control at lower volumes without sacrificing your tone. The bass, mid and treble controls interact with each other to give you a wide range of tones. The Bass Emphasis switch changes the center point of the mid frequencies allowing you to get even more bass out of the amp. The bright switch is designed to bring in enough top end for even the darkest guitar but without adding any ice picky highs. This amp was designed to be that familiar black face styled tone from the mid 60’s but with added clarity and string to string definition that is unrivaled in any similar design. This is a LOUD 22 watt amp. You will be pleasantly surprised with its light weight and small footprint especially when it blows much larger and heavier amps out of the water. Handwired in the USA.
Specifications
Power: 22wClass A/B tube
Hand-wired in the USA
2x 6V6 power tubes
3x 12AX7 preamp tubes
3 Spring tube driven reverb
Bright switch
Bass Emphasis Switch
Volume, Treble, Mid, Bass and Level Controls
2x8 ohm 1x16 ohm outputs
Custom USA made Mercury Magnetics transformers
Made in the USA
