Could this switch strymon favourites?
sgosdensgosden Frets: 1994
http://www.nuxefx.com/show-9-243-1.html
El cap needs trs switching for the favourite function. So in my mind you could go between latched ring to latched tip on this for the same effect? Making it possible to switch the favourite function via midi?
  • John_AJohn_A Frets: 3775
    Dont know , but good luck finding one I think they have been discontinued.  I bought one a while ago for a amp switching system and got it from a shop in Slovenia as no-where had them in.  Haven't used it, so it you want it give me a shout
  • sgosdensgosden Frets: 1994
    @john_A I may take you up on that.
    Looking at this again with a good night's sleep behind me, i think it'll work, but will have to rewire a trs cable so that the sleeve is common instead of tip (like on favourite switch).
    Not 100% certain, but I think you can do that with the settings on the PMS, you can view the Chinglish manual online
