Refinishing a guitar without making it perfect?
Hi fretboarders,
I’ve got a 90s US standard Tele, which I love to bits. It had a poly finish until a few years ago, when I stripped it (fairly inelegantly), stained it and gave it a couple of coats of Tru Oil. Since then I’ve toured it pretty heavily, and the wood has got its fair share of scrapes and bumps.
I’ve now decided to refinish it in nitro, so I’ve sanded off the Tru Oil and as much of the stain as I can ready for grain fill, primer and colour/clear. There are still quite a lot of knocks visible - which I kind of like since it’s a 20-year-old guitar - and I just wondered if refinishing it over a less than perfect body would look crap? Will the grain filler even it out anyway if I do it properly?
If anyone wants to chip in with their superior wisdom, that’d be much appreciated!
  • thermionicthermionic Frets: 9610
    I’m no guitar finisher, but I’m sure you could get a perfect finish by steaming out dings and/or wood filler (not grain filler). Assuming a solid colour of course.
  • rexterrexter Frets: 369
    If it's got a lot of deep gauges in it i would use something like an acrylic putty to fill them. Especially if you're going to paint it a solid colour. Grain and wood filler aren't that good for filling deep imperfections. I would normally start by giving a 'bashed around' body a good sanding (always using a block or DA) up to 400 grit then filling the visible dents/dings. Sand flat again -  be careful  to preserve the roundover on the edges.
    Do your sealer and primer and then look at it carefully and fill any imperfections you can still see with the putty (most bodyshop type products work nicely over primer). I would then sand flat, prime again then flat that back as smooth as possible before the colour.
    I use this stuff a lot - it's cheap and can be found easily but works really well:
    https://www.halfords.com/motoring/paints-body-repair/fillers-preparation/holts-cataloy-knifing-putty-100g
    In my personal experience - before doing this professionally too - it's worth doing the prep to start with because if after a month-long finishing process you end up with a result that doesn't thrill you, you'll want to start again (at least I used to) and it's painful to strip everything off and start over.
    Just my take on it anyway!  :)
    Custom colours, vintage restorations, high end guitar finishing
    www.rexterguitars.co.uk
  • dwheeldodwheeldo Frets: 65
    Great stuff @rexter, thanks for the info! I don’t necessarily mind a few imperfections in the finish, but I’ll heed your advice and take my time with the sanding. I’ve done plenty of DIY woodwork around the house, so I guess the same principles apply. Sanding, filling, sanding, painting, filling, sanding, painting...Should keep me busy for a while ;)
    No worries, cheers. Yeah... all the boring stuff! It does pay off though. Spraying the colour is the really fun satisfying bit, but ironically the part you spend least time on!
  • WezVWezV Frets: 16665
    It depends what end result you are after.
    if you want to relic and keep/recreate existing wear then you have some options for leaving it.  But you need to have some experience of relicing to get that looking natural.
    Its actually much easier to deal with the issues properly as said above
  • IvisonGuitarsIvisonGuitars Frets: 6838
    How did you get on with the Tele refin and masking up the original wear Wez? Did you post pics anywhere?
    http://www.ivisonguitars.com
    (formerly miserneil)
    edited July 2018
    No pics of the back posted yet, but it’s looking really good.  I want to save some surprises for the end on that one
    peeling off the tape was a ball ache, it had been on longer than I usually leave for binding and left some sticky residue, but all sorted now.
    anyone not sure what we are on aboue, I taped up the back of a guitar like this
    to keep the wear it had in its last refin (edit:  the red paint below is an old refin now removed, but it had worn nicely so the challenge was to keep the wear
    That was done for the extreme wear   Normally i do a lot less than that.   I simply let the lacquer sink into the flaw and the use the obvious imperfection as a guide to recreate the damage afterwards
    Excellent work as always @WezV.
    The knocks on mine aren’t too crazy, so I’m just planning to get the surface as flat as I can before I start. Then once the grain’s filled and I’ve added the primer I should have a better idea whether or not to patch it up any further.
    I don’t want to relic it, but equally I’m not too fussed about having a perfectly smooth finish either.
    If you don’t want to Relic it then you definitely want to fix the issues.
    Noted. I’ll get down Screwfix for a job lot of sandpaper!
  • axisusaxisus Frets: 28333
    @WezV That red body looks so cool! Real good job there.
    Lol.  The red is an old refin, I have removed it to restore the original colour
    Thanks for the tips so far. I've spent this morning sanding and grain filling in the garden, sweating like hell in our newfound tropical climate. While I'm waiting for the filler to dry, I thought I check the other stuff I need.
    If I want to finish in a solid colour, am I right in saying that after grain filling, I just need to use primer (with no need for sanding sealer) before a couple of coats of colour and clear? I'm planning to use the white primer that @SteveRobinson sells, followed by olympic white nitro and a clear gloss to finish. Sound good?
  • SteveRobinsonSteveRobinson Frets: 7024
    You don't need sanding sealer but I prefer it as it's harder than primer and penetrates the wood better I think.
    Once the body is primed, I'd fill all the holes with Ronseal high performance wood filler sand smooth and prime again. Keep filling and priming (you'll probably miss bits on the first pass) until you have a perfectly smooth substrate. Then spray the white.
    Thanks Steve. So do you mean use the clear sanding sealer first, then fill and build up coats of the white primer?
    Yes that's what I'd do but there are lots of ways to achieve the same results and others will probably have their own way of tackling it.
    Ok, gotcha. There’ll be an order coming your way tomorrow...
    The rattle cans have arrived (thanks @SteveRobinson), so I'm planning to get started on the spraying at some point this week.
    But before I do, I wanted to check what to do about the neck pocket - I definitely want to cover the plate with the date stamps on, but should I cover up the sides as well to make sure the neck still fits properly?
    I see most people use a painting stick in place of the neck, and this is what I was planning to do. Are there any disadvantages to this method, and does the wood need to be exactly the width of the neck?
    I guess as nitro should be pretty thin I may be worrying about nothing, but it's always best to check!
    I never mask the neck pocket although plenty of people do. Be careful not to overmask near the edges, it's easier to scrape back a bit than add lacquer to the edge.
    For a painting stick I have a length of 1" square-section tube drilled and tapped to take M4 machine screws. I appreciate this is overkill for a one-off job!
    Yep, I might see how this first attempt goes before I make anything as heavy duty as that! I've got some inch-thick batten in the loft which should do the trick, but I think I'll leave that until I've sealed the body (including the neck cavity).
    Is there much value in blocking the ferrule holes? I saw your handy video about using a soldering iron to get them in, but mine are already a pretty snug fit.
