Impact-Related Lacquer Cracking or Neck Break? (Vintage-ish Ovation Electric Solid Content)
HarrySevenHarrySeven Frets: 8017
edited July 2018 in Guitar
I'm thinking of parting with this...
Yes, it's an Ovation Preacher Deluxe. All the active stuff works (albeit with a few slightly noisy switches) and it sounds rather nice.
However...at some point in it's life, it's had a wee bump...
NB. I've upped the contrast on these images so the damage is more visible.
I'm pretty sure it's not through to the wood (@ICBM, @WezV - what say you?), but it is a little unsightly.
Now, such things don't bother me (it's perfectly stable and plays fine), but I do realise this is a bone of contention.
It's not a particularly rare or valuable guitar, so sinking money into a localised refin doesn't make fiscal sense.
Hypothetical question - presented with damage such as this - would it put you off a purchase? (that's supposing you were in the market for a weird old Ovation solid*)
*Either that, or (if you can’t suspend disbelief), just imagine it’s a tasty LP or SG you fancy.
Forum feedback thread.    |     G&B interview #1 & #2   |  https://www.instagram.com/_harry_seven_/
  • FunkfingersFunkfingers Frets: 14321
    Is it a photographic aberration or is there a dead straight line feature, running down the centre of the headstock, through the area of finish damage and along the mid line of the neck as far as the shaded area?
    Be seeing you.
  • HarrySevenHarrySeven Frets: 8017
    There is indeed.
    Two-piece neck?
    Be seeing you.
  • BridgehouseBridgehouse Frets: 24578
    Two-piece neck?
    Not uncommon with Ovation IIRC - that's def. a two piece as there is grain mismatch as well.
    The question that you have to ask yourself is this.
    How likely is it that a classic headstock break "smile" crack would traverse the glue joint that runs along a two-piece neck?
    Be seeing you.
    I was thinking along similar lines..
  • valevale Frets: 1052
    edited July 2018
    i don't have enough experience of these things to call it, but if people who know have acces to basic desktop photo edit facilities, if you desaturate the last big image in harry's op, then roll up the brightness of the black & white image you are left with, it looks as if there is an upper & a slight lower line, maybe 15mm apart (you can play around with contrast too).
    but desaturating the whole image extracts the random mid-tone red wood hue from the basic contrast black & white tones.
    with the little knowledge i have, my guess would be it's a very shallow fracture from a bump but there wasn't a full-on break. old varnishes can be superglassy brittle & can crack & crumble under the tinest stress.
    & if it's a nitro finish, maybe some of that clouding came from a stand or hanger with a wrap around foam headstock support.
    ovations seem hit & miss to me. i like their basses (magnum) better than their guitars.
    hofner hussie & hayman harpie. what she said...
  • WezVWezV Frets: 16541
    I don’t think you can say it’s not a break.
    I would be tapping the headstock and neck shaft to establish whether they resonate as one
  • ICBMICBM Frets: 71953
    The neck is a three-piece - the middle piece is just over 1/4" wide, and for some reason is slightly off-centre on this one.
    In my opinion the headstock has been broken and repaired - although I would need to see it in person to be sure.
    It's not at all impossible for a break to go straight across all three pieces like that, the grain is very nearly parallel and the weak point is in the same place for all of them. I've seen it many times on Gibson 70s 3-piece necks and even things like Ekos where the middle piece is a different wood - and plenty of Firebirds and Thunderbirds which have multiple pieces.
    If I wanted the guitar it wouldn't stop me buying it, but it obviously would affect the price slightly. If you're selling I would definitely describe it as a probable headstock repair.
  • HattigolHattigol Frets: 8175
    A straw poll, hay?
    "Anybody can play. The note is only 20%. The attitude of the motherf*cker who plays it is  80%" - Miles Davis
    In that case, I think I may very carefully remove the lacquer in that area for further investigation.
    WezV said:
    I don’t think you can say it’s not a break. I would be tapping the headstock and neck shaft to establish whether they resonate as one
    The finish around the suspect area is strangely crinkly and/or shrunken. Does this continue all the way along the length of the neck and the back the headstock?
    Be seeing you.
    It’s all very well, you lot preaching on about it...
    I only have to mention "crinkly and/or shrunken" then, you appear. :-p
    Be seeing you.
    Yes - now I'm looking at it on a full-size screen, that doesn't look like original Ovation finish at all. The original finish should be very hard, shiny and smooth - it does quite often crack, usually due to temperature/humidity changes, but in long straight lines. That's what I assumed the thread was about...
    There's also a patch on the neck extending about 1/2" to 3/4" from the suspect line which looks like the original finish might have been scraped or sanded through, in which case the crinkly finish is overspray.
    In a few days, I’ll start doing some careful investigation.
    Watch this space! :)
    Would it not be wiser to leave well alone?
    Declare a repaired break. Adjust your asking price accordingly. Let the next owner decide how much money to throw at the guitar.
    Cleaning away the repair finish undermines your argument that the repair is good and stable.
    Be seeing you.
    Sounds reasonable.
    But...in that case, what would a notional value be for one of these? (with the identified repair)
    Probably about 75-85% of the value of an unrepaired one in the same condition otherwise.
    The relative rarity - compared to something like a Gibson - does count in its favour.
    @ICBM - the nearest I can find are Viper variants, which seem to be in the £550 - £750 region.
    In terms of this Preacher Deluxe, I’m guessing ‘as is’, around the £400-ish mark?
