Helix question
RMJRMJ Frets: 1274
I have my laptop connected to Helix via USB and am monitoring Helix via monitors/speakers.  Can I listen to the laptop though the speakers?  I cant seem to do this, though I can listen to the laptop output via headphones.
Best regards
Technonoob
  • TeetonetalTeetonetal Frets: 7802
    Yes. Do you have Helix output on multi?
  • shuikitshuikit Frets: 224
    So, your speakers are connected directly to the helix yea?  Assuming you're using windows, you need to change the 'playback device' to Helix.  Right click the speaker icon in the system tray (bottom right next to the clock) select 'playback devices'.  Then you should see a dialog and the Helix should be listen in there, then right click that and 'set as default device'.
  • RMJRMJ Frets: 1274
    Hmmm maybe not.....
    I'm using Mac but same principle applies i guess...will check in settings
    Thanks guys
  • Just change the laptops audio settings so that the in and out are helix
    Done all of the above and still no output from laptop....
    sorted - global settings!
