Jazzmaster - top E string unwinding
DarnWeightDarnWeight Frets: 2566
Now the owner of a Jazzmaster, and just had the top E string unwind at the ball end after only very mild trem wiggling.  Have looked around the usual places, and it appears that, yes, this is a thing.  I would have been restringing with 11s anyway, so no biggie, but wondered if there's a way of alleviating this in the future.  Read about one or other of these helping...
- finding the "right" string brand
- soldering the winding at the ball end of the plain strings
- flipping the outer two pivot plate screws so the heads don't catch the string as it passes over them into the tailpiece
- shimming the neck and raising the bridge
- fitting a Mastery vibrato
Anyone with any first-hand experience of this like to share tips/tricks?
Cheers!
New fangled trading feedback link right here!
  • impmannimpmann Frets: 12649
    Yes, its a thing.
    Flip the pivot plate screws if they are fouling. I also cut them down a touch too, so they became flush with the plate.
    You can shim the neck to give a bigger break over the bridge and this can give better clearnace over these  screws, but I prefer a belt and braces approach.
    I found GHS strings were better for this - the wrap seems more 'robust'.
    Mastery trem is a work of art, but pricey.
  • FunkfingersFunkfingers Frets: 14324
    Soldering over the string end wrap will prevent unwinding. It might not prevent the loop around the ball end itself getting severed.
    I vaguely recall that this problem may stem from the string anchoring holes in the tailpiece - especially non-US versions. Check the hole for sharp edges with the potential to cut through the strings. Abrade them smooth.
    Be seeing you.
  • GagarynGagaryn Frets: 1553
    edited August 2018
    Yip, modern pivot plate screws have a slightly higher domed head than older ones so the strings can rub on the head and cause string damage. Easy first step is to polish the dome (ooh err!!), either with a Dremel or go through the grits with micro mesh or wet and dry, if you are lucky you can make the head smooth enough and lose just enough height that the problem is eradicated.
    But if it looks like you would need to lose too much material from the screw head for it to be viable then the other option would be to flip the screws so the heads are on the inside as @impmann suggests.
    Would be wise to check the string holes are not the problem too - as @Funkfingers said, the holes can develop burrs that can damage strings though that seems to be more of a problem on unwound strings - still worth checking though. Mitchells abrasive cord is perfect for smoothing out the edges of these holes.
    I'd be reluctant to shim the neck to resolve this single issue as you could introduce other just as annoying issues.
  • meltedbuzzboxmeltedbuzzbox Frets: 10337
    from my experience the screw heads haven't caused string breakage on my offsets. My two current ones have contact on both E strings.
    I have had a burr inside the string hole on the tailpiece which was causing string breaks on a MIM classic player. A quick pass with a small file sorted it out.
    but I know a lot of people, even with the mastery system and a well filed hole (giggity) still get mystery string breaks :-S
  • francerfrancer Frets: 369
    I usually go for solder or occasionally I buy Fender Bullets.
    I know a lot of people do it, but I'm not sure about flipping the screws, they're only threaded into the pivot blade side so flipping them over means they no longer help to clamp the blade in place and simply become locating pins leaving the middle screw to do all the work holding the tremolo pivot in place. I'm sure it does work but seems wrong to me.
    I'm fairly sure the last one I did had a thread on the plate too...
    Actually, I'm not a 100% sure myself, although reading my previous post I certainly sounded pretty sure, but agreed if both parts were threaded would work fine.
    They are threaded on both parts.
    I use flatwounds with silk wraps and have had the silk fray with rough screw heads but no string breaks. I can see how it might happen though.
  • DarnWeightDarnWeight Frets: 2566
    Thanks everyone.  Just to be clear, the string definitely unwound at the ball end, not snapped.
    BTW if model/country of origin has a bearing on any of these minutiae, the guitar is a US 60th Anniversary '58 reissue.
    to be fair I have seen the odd string just unravel. ITs rare but it does happen.
    How many strings have you gone through @DarnWeight ;
    Thanks for confirming! I thought I was going mad... ;-)
    If it's happening right at the ball it will be a burr on the hole. If it's happening a bit up the wind at the ball end it will be the screw.
    Or it could just be a duff string if it was a one off.
    I'd smooth off the holes in any case to rule out future problems, either with a small needle file or even more effectively, Mitchells abrasive cord.
    It's just one at the moment, but that was after only about an hour of light play, and the guitar is essentially brand new. Never had one unwind at the ball like that on any other guitar, so a quick google opened up a whole world of theories and fixes!
    I'm probably just going to string it up as is with a set of Daddario 11s I've got knocking around (one of the balanced tension sets), check to see if it's contacting the pivot plate screw, and see what happens.
    My old AVRI did this - but only if I slackened the strings to adjust something, then retensioned them. Very quickly afterwards the top E would unravel.
    Eventually, I ran some abrasive through the holes in the tailpiece and *bingo* no more issues - or rather, less!!
  • PhiltrePhiltre Frets: 4164
    A D'Addario 10 E string unravelled on my Jazzmaster 65 vintage re-issue after a frenetic tremolo waggling session not so long ago. I thought it was puzzling at the time, but I think it must have rubbed on the screw head.
  • HattigolHattigol Frets: 8176
    I have the exact same guitar. And the exact same issue.
    Replaced the top E with an Elixir - seems fine, although you can guarantee that I have just jinxed it by saying that!
    "Anybody can play. The note is only 20%. The attitude of the motherf*cker who plays it is  80%" - Miles Davis
    edited August 2018
    Hmmmm, I just removed one of the screws on my AV65, and given that it’s actually quite hard to tell without disassembling the whole thing, judging by the way the screw drops into the hole a mm or two before resting on the threads, and feeling for threads on the inside of the top plate hole with a pin, I’m fairly sure that only the underneath plate is threaded.
    Same for my CIJ.
    YMMV
    Managed to dig out a single .010 gauge E string (I normally use 11s across the board), and whacked it on the JM.  Looked uncomfortably close to the pivot screw, so raised the bridge a touch and it's clearing it fine now.  The action from stock was super slinky and low straight out of the case...I tend to prefer a slightly higher action, so this little tweak is really no big deal to me, and should help me isolate what's going on.  I'll give it some stick and see how it holds up before restringing with a set of 11s.
    Thanks again for all the advice and info.
    Just discovered these - longer wind to help alleviate the problem - https://www.homeoftone.co.uk/collections/best-sellers/products/the-gts-co-gt-rounds-11-50
