Solo of the Month (SotM) #41 - Chat
  • Rowby1 said:
    Wow guys! They’re great!! Think I’ll pull a sicky this month :)
    If you do we will find you and Melvin you :)
    Only a Fool Would Say That.
  • ModellistaModellista Frets: 2039
    In terms of recording gear, I used my latest  budget studio gizmo, AMPLIFi TT, set to some kind of slightly crunchy blackface setting, a Visual Sound Route 66 compressor with the gain high, and a bit of the drive side for the climax.
    Oh yes, and one of the infamous discounted R8s doing the heavy lifting.
    Usually I amalgamate the best of a few takes but did this in one take because I wanted a video for the R8 thread.
    https://youtu.be/juE38fI6Ots
    0reaction image LOL 1reaction image Wow! 3reaction image Wisdom
  • flying_pieflying_pie Frets: 1816
    edited October 2018
    Sent.
    Great track. From a single listen I immediately got a melody in my head, recorded it then my computer crashed just as I had to go out. I think I've managed to recapture what originally didn't save!
  • I'm away at the moment. I'll update the playlist when I get back.
    It's not a competition.
  • markvmarkv Frets: 459
    Entry sent.
    My approach was mostly based around the chords, with specific notes I wanted to hit at the chord changes, and in particular trying to make the transition from an Emaj scale to Emin (and back again) sound natural. Not 100% I achieved it going in, coming out I'm a bit happier. The sound was the neck pickup on my GS, a simple clean tone through the amp, with some EQ and reverb in Reaper.
  • fastonebazfastonebaz Frets: 4087
    I was thinking of doing a video too as I tend to record all mine in one take (just that there are 100s of takes lol).  I like watching how it's played.
    I did play mine all in one take (after lots of practice, yes!) ... but actually, the version I've submitted is about 5 segments merged together, since there's a couple of awkward transitions that flow better if they overlap slightly.
    That video is great @Modellista
    @ very interesting to see it played and more videos all round would be great.
    I tend to record around 90% in a single take then spend a bit of time messing around with the trickier chord changes. I also like to have some ad libbed phrases phrases which can be very hit and miss and might involve a lot of takes.  I could do a video in the future but it would probably look like a cassette boy edit.
    On this occasion I went with an immediate melody in my head which was the basis of the first few phrases. I then tried building on it with my focus on avoiding my default pentatonic clichés.
  • Rowby1Rowby1 Frets: 1271
    @Modellista Great video. I have no idea how to record video like that. What software do you use to put the audio from your DAW with the video?
    Cheer @Rowby1 and @flying_pie ;
    It's done in Premiere Pro, quite easy to import the footage and audio together.  Tricky part is getting it synced, I just eyeball it until it looks right.
    Hard part is playing it properly and not gurning too much!
    Re: the synching - perhaps you could give yourself a few bars space before the backing track starts and strike some muted strings once in the silence.  That should give you a clear spike on the original audio as well as the recording and you could use that to line the audio tracks up
    I guess that's why filming uses a clapperboard? It's a sharp sound you can use to line up audio and video.
    I've experimented with video in Reaper, it can do simple video processing, and audio processing of course.
    Yes that’s a good idea. Annoyingly Premiere Pro doesn’t seem to want to give a waveform of the audio - there must be some setting or other. Anyway for the few videos I do just doing it by hand is fine.
  • SteveFSteveF Frets: 536
    @Modellista ;https://youtu.be/Uh88_WoHYL4
    clapping seems to be the standard method from the few few videos I’ve watched on the subject.  I think there’s an auto sync setting somewhere but I’m not familiar with Premier.
    ^ that’s cool. My old version of PP doesn’t have auto sync, and the waveform doesn’t appear for some reason on the Wav file so personally I have no choice but to fudge it!
    In fact I hate Premiere Pro a bit. Seems like the least intuitive software I can remember.
    @Modellista I use Hitfilm Express.  It's free and awesome.   They have audio wave form to help align video to audio. Tapping the strings or pickups is a good way to help simulate a clapper.  I looked at a coupe of Adobe premiere tutorials and the two products are very similar so if you made the switch you'd probably be up and running in no time.
  • Sent.
    markv said:
    Entry sent.
    Added to the playlist. 5 entries so far.
    Appreciate the recommendation. Certainly will give it a go. Hopefully I’ll get on with it better than PP.
  • @Modellista great to see a video.
    I might have a go at that one month. This could be the start of a new trend.
  • Entered! Even though it's my backing, I found that bugger really frustrating to get somewhere near.
