These are good amps for the money.
Behringer’s description is usually that it’s a revolutionary filter that lets you change the shape of your sound. Useful.
IIRC it’s a sort of cross between a parametric eq and a notch filter - anyway, whatever it is it seems to be similar to the one on the Hartke preamps and is bloody useful!
I'm surprised that Bridgehouse approves of this concept. Reduced mids and increased top and bottom usually equates with a white person attempting SLAP BASS. :-p
The Hartke one does have a mid flat point which means that if you dial it up it gives a slightly bigger low mid hump, and rolls off a bit of top and bottom - almost anti-slap
They so some other ones with VU meters... I wonder what they're copies of?
FTFY
I always use a scooped sound - it fits around the guitars much better and leaves plenty of space for them in the mix, while also making the dancefloor shake... which is surely the point of bass!
