Not sure what it’s worth though.....
I have been been collecting this stuff for years having had a vintage fender amp obsession in the past. I’m nearly cured now.
https://imgur.com/gallery/VcfpgjB
Where are you in the country? Posting these is tricky as the wires connecting to the springs are very fine and easily damaged. Probably why yours is broken.
I can't make out the model number from the photos maybe that will help determine whether it's a good candidate for a princeton reverb.
GENEVA, ILL
PAT. 2,982,819
3,106,610
Ink stamped 4AB3C1B
Thanks
supposedly the 4AB3C1B has a longer decay.
I'll let you know if something doesn't work out, but at the moment me and @Ossyrocks have come to an agreement.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
I've had it sat around for ages hoping it'll come in handy for something - think I rescued it from a dead 1970s or early 80s solid state PA head (probably a Carlsbro or HH).
I'm sure you've also come across a few where people have just shoved something like that in to get it working...
I really like the Ampeg Reverb and have used this circuit in a few builds.
In fact I'm just completing an amp that employs a 12DW7 as a reverb driver and recovery stage, using the 12AU7 side of the 12DW7 to drive the reverb and the 12AX7 side as the recovery amp. (Well in theory; I can't find any 12DW7s in the workshop!!).
