soundcloud.com/thecolourbox-1
Generally a Fender or similar into a Fender or similar. Minimal drive, good volume. I like the sound of rooms, so tend to record with a mic set at some distance. This is a good example, although posted before.
https://soundcloud.com/menamestom/fender-nocaster-test
Feedback
While I guess it's an acquired taste, I can get lost for hours with that sound.
I said maybe.....
Clean Fender or plexi (so Bassman) amp or equivalent digital model.
Drive pedal more or less always on and set to edge of breakup and compressing slightly so can do clean or more grit/sustain depending on right hand and guitar volume control.
Delay with low mix level with lightly modulated repeats and/or plate reverb for a bit of subtle movemebt/ambience.
Stack with a distortion pedal or fuzz — but not heavy square wavey fuzz — for more rock/fusion lead.
Yes, I use pedals.
https://youtu.be/oUKhdwTb204
With the Les Paul, volume open and fuzz
