My guess if there is a lot of different stuff wrong involving the switching, loop and reverb, that it could be something to do with the low-voltage (probably +/- 15V) power supply circuit… although a non-working and noisy reverb can also often simply be a broken return transducer connection in the tank.
The Camel schematics are almost certain to be completely different, it's a valve amp.
If you really can't find anyone who will take a look at it where you are without costing you a fortune (if it's not something simple), PM me - I would be willing to look at it and there may be a possible way of getting it to Scotland as long as you're not in a hurry!
http://www.sporting-heroes.net/content/thumbnails/00173/17216-zoom.jpg
https://www.ebay.co.uk/itm/Carlton-ProSeries-Combo-Amplifier-/302620188939?
Is this one of the "*worst*" ones?? Seller seems to disagree
https://www.ebay.co.uk/itm/Carlton-Camel-50-all-valve-amp-Scots-Boogaloo/332543199080?hash=item4d6d1e8768:g:dxkAAOSwdd9abIlM:rk:1:pf:0
”don't confuse this with Carlton's solid state amplifiers this is a whole different animal.” They certainly are .
The £375 the seller is asking for the wicker grille one sounds a bit optimistic but probably not completely bonkers.
Give it a try - you may even like it, I don’t know! Some people like 90s Trace Elliot valve amps too .
