What is your ‘sound’?
12346»
  • dindudedindude Frets: 8537
    gordiji said:
    Crystal cleans here,
    Now that’s what a Tele should sound like! In my hands they sound like broken glass unfortunately.
  • MT-2 into MT-2 into MT-2 into MT-2 into MT-2 into MT-2 into MT-2 into MT-2 into JCM800
    All in bypass mode?
    soundcloud.com/thecolourbox-1
  • ICBMICBM Frets: 72311
    Gassage said:
    Joking aside and answering properly, low gain mid hump dirt into a clean loud old fender with deep analogue delay, without the repeats being obvious, is my goal.
    The repeat seems pretty obvious there...
    Needs to chill with his delay pedal  ;)
  • RockerRocker Frets: 4980
    Play it again Sam.
    Nil Satis Nisi Optimum
  • thebreezethebreeze Frets: 2801
    gordiji said:
    Thank you thebreeze, Tele it is ! Is your name reference to the jj cale classic .
    History is junk, your prize is a thank you !
    Yep - big JJ fan here.  My prize is hearing all you guys play.
  • kt66kt66 Frets: 315
    edited October 2018
    this is my holy grail guitar tone. And after too many years I have it.
    All in bypass mode?
    No. Flat out, man. All flat out.
  • EggmanEggman Frets: 43
    For lead, Mick Ronson. He played a Les Paul custom through a 200w Marshall head that he called 'the pig'.
     For rhythm, a tele on bridge pickup through a blackface. Lots of treble, not too much mids and lots of lows. Subtle amount of delay.
    A mix of crystalline spiky post punk cleans followed by a thick strident hi gain crunch, followed by a kinda Gilmour/Billy Howerdel type lead sound.
    My sound these days tends to be mainly humbuckers with some gain.
    I shouldn’t really be posting this as it’s a private Soundcloud link - I’m working on friend’s project - this is the outro solo:
    https://m.soundcloud.com/paul-willocks/is-this-richardss-solo-the-final-take-14-080918/s-vDNeC
    Needs more bass :D
  • richardhomerrichardhomer Frets: 24801
    edited October 2018
    Needs more bass D
    Are you offering? Right now what’s needed most is my friend deciding which chord structure he’s using in the verses, finishing the lyrics and a good male and female singer.... The first recording session I attended for this was in January. Aries people are not noted for their patience.... :)
  • Breaker86Breaker86 Frets: 13
    edited October 2018
    Hi all new here but thought I'd share my sound.
    My sound is a mixture of bitey cleans and octaved dirty naughtiness.      I play mainly instrumental math rock/prog music but my former band was an odd mix between punky/indie riffery with some sax thrown in for good measure.
    I've been focusing on writing my own songs for months now and I'm finally getting to a stage of getting them recorded but it's a slow process haha!
    Gear wise I'm running a Cort TC classic into a Hayden Mofo and some very lovely pedals.   I'm a bit of a cliche when it comes to the pedals I use at least in terms of the music I play but it's all good fun.
    For my clean stuff as an example though pretty dated:
    For far more recent riffs and fun I've yet to sit down and record them properly so:
  • JerkMoansJerkMoans Frets: 8794
    Right now I'm achieving tonal nirvana with my @FelineGuitars LPJ through a 3 Leaf Wonderlove and into my LJ20 for a funked up porn soundtrack version of Chameleon.  Uh-huh baybeh.
    Inactivist Lefty Lawyer
  • ReverendReverend Frets: 4999
    Les Paul in jmp 2203 into greenbacks. Set tone controls to 12 o'clock and then adjust to suit the room and stage. Gain usual about 2 o clock. That's my clean. Guvnor or bad monkey for Rythym with gain set just about half way. Wah or phase 90 for leads. Tonally aiming for somewhere between the first and fourth trouble albums which are probably the best guitar tones in metal.
    Used to crank the low end but realised over the years that cranking the low end doesn't make you heavier  - the bassist has the low end.
    Pretty much every gig Brule has done I have had someone comment on my tone.
