Two important questions:
Does it have an undersaddle pickup? If so lowering the action is usually a more demanding job than if not, assuming it's the saddle that needs to come down as well as the nut and/or relief.
Do you know where you want the strap button fitted? There are three common positions (two on many guitars, but a Gibson will take the third) - on the back of the heel; on the heel pointing directly up the neck (not possible on guitars with a pointed heel); or on the underside (treble side) of the heel. Be careful that whoever fits it doesn't just whack it on the back of the heel, if that's not where you want it - a 'luthier' did that for someone here. It's not a good place usually.
NB, I'm a guitar repairer with over thirty years' experience but I would never call myself a luthier, because in my opinion that's someone who *builds* guitars, and I don't. But I can certainly fit a strap button and lower the action correctly.
The best way to do that is with a sanding board - a flat board with sandpaper glued to it that you move the saddle on, not the other way round. You can do the bulk of the cutting first with a saw or file, depending on how much needs to come off.
