In the mid nineties, my Dad walked with me to Gig sound and I bought my first guitar a £49 Brunswick acoustic for my birthday. For years I played it until I realised how rubbish it was! I replaced the tuners, had a bone nut installed, had the neck levelled, Ablone fret markers put in (To replace the shockingly bad plastic ones that were proud of the neck, refretted it, had a bone saddle installed and replaced the bridge pins for tusq. I have a lowden and a d28 but everyday I play this guitar, I've probably spent over 8 times what the guitars worth doing it up. I know it will always be a cheapo ply thingy but it sounds pretty alright. My dads not around any more and it means even more to me now. It's the one thing I'd run into the house to save if it was on fire.
The intonation is shocking, open/harmonic it is so sharp and its like that all over the neck, no 2 same notes intonate the same. Suggestions guys? I'd be happy to go down the whole new bridge route.
If it’s OK the chances are you may need the bridge saddle moving, or the slot widening and a compensated one fitting.
I would check it using a tuner with a cent scale first and see how bad it is.
Have you measured the scale and the bridge position? If the bridge is in the wrong place, then that could be an issue.
Before replacing the entire bridge, I'm not sure to the exact repairs but either the saddle slot could be widened for extra compensation or you could maybe use an overhang saddle? Chris Alsop sells them at his website.
