For pedal order, I would suggest delay, then reverb, then looper.
There's a the Boss RE-20 which is excellent but costs about £150 second hand. Recently a Nux pseudo-clone of it has appeared which is half that price and is apparently quite good but I've not tried one.
Cheaper, you can pick up the Digitech Obscura which has a nice tape mode on it.
Also, shout out to the DOD Rubberneck which Thomann are selling very cheap at £110 right now. Not strictly a tape delay but anyone buying an analogue voiced delay right now should check them out.
The NUX Tape Core is the Boss tribute pedal but doesn't seem to quite do the crazy stuff ( may not be a problem) and you need to plug it into the online editor to use the built in reverb and do more detailed changes).
