Slight lag recording in Audacity
I've been using Audacity to record myself playing along to an MP3. When I'm playing it all sounds in time, but when I play back my track lags about 150ms behind the original track. I assume there must be some sort of buffering issue going on, but what's the best way to fix it (other than just snipping 150ms out of the start of my track)? Any tips, or is Audacity just not really the right thing to be using?
  • steamabacussteamabacus Frets: 1263
    edited October 2018
    I use Audacity all the time but only as an audio editor, never for multitrack recording.
    But, if you look in Preferences : Devices you will find a section labelled 'latency' with buffer length and latency compensation. My latency compensation seems to be set at -130ms although I've never calibrated it.
    Read here (bottom of page) and follow the link to Latency Test ....
    https://manual.audacityteam.org/man/devices_preferences.html
  • Thanks - will give it a go.
